Easy fix for understeer
Old Mar 8, 2003 | 12:31 PM
AndyB's Avatar
AndyB
Default Easy fix for understeer
While waiting for my Z I have been reading everything I can. I have heard about the "resolute understeer" and then I saw that the front tires are 2 cm narrower than the rears (I ordered the performance model).
So, I was wondering, if you put the same width tires on the front that are on the rear (+20 in the section width) wouldn't you increase the front grip just a little and balance the steering out a little more. It might not be a complete fix, but it would be a lot cheaper than a while new suspension kit or something. Besides the stock tires are gonna get replaced pretty quick anyhow.
Anyone tried this? Any reason (like clearance) not to do this?
Old Mar 8, 2003 | 07:15 PM
krinkov's Avatar
krinkov
yep, wider front tires reduces understeer, what wheels do you have (17.18. track?)
Old Mar 8, 2003 | 08:26 PM
FlyingToaster's Avatar
FlyingToaster
Same width tires with rears will not necessary give you same amount of patch on the ground, since the rear rim width is 0.5" larger (I am assuming the performance model uses 8" fr and 8.5" rr rims).
Managing understeer, IMHO, should be done with a combination of wheels/tires, suspension and sway bars. The important point to manage is the weight transfer, which too much of it to the sides and fronts creates understeer. Since the 350Z's 57% weight is on the front axles, during cornering significantly more weight will be transfered compared to the rear of the car. If my assumptions are correct, then changing tires size only will not give you much of a different ride.
Also, I would highly recommend you first drive the car and then try to adjust according your driving skills and enjoyment. Understeer is a good thing for regular driving. Unless you are a very experienced driver, I would not recommend trying to put more oversteer.
Old Mar 9, 2003 | 03:02 PM
zwindsor's Avatar
zwindsor
Twisty addict
AndyB
Your Performance model comes with 18x8's on all corners so the contact patch would be the same for all. Yes, it will help reduce understeer.
Old Mar 9, 2003 | 06:38 PM
D_Nyholm's Avatar
D_Nyholm
If you are having slight problems with understeer and are racing a bit, try adding air to the rear tires. That will tighten up the rear suspension and make it grab a little less giving you more rotation in the turns. Should help a few people here.....
Old Mar 9, 2003 | 07:35 PM
ares's Avatar
ares
Veteran
for the record, in the perfect world, physics dictates that same if your working with a fixed amount of friction on the tread, by increasing surface area, your decreasing pressure. negating all effects.
now if your new tread was grippier, youd have a case... but just by getting wider tires, you wouldnt really increase traction by that much.
Uriyo_
Sep 8, 2021 08:46 AM
Rev_Night
Nov 7, 2020 06:00 PM
Cashwin
Oct 1, 2015 06:36 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
