AAM Fuel Return System!
Old Oct 3, 2006 | 01:12 PM
Mr_pharmD's Avatar
Mr_pharmD
Originally Posted by skyydiver
Yes, it does help! Thank you so much Mike. My only problem with going with the Tuner version of the Vortech and the UTEC or HKS F-Con Pro is that I do not have anyone in my area that can tune that thing. I suppose I could learn how to (because that is what I had planned on doing with the Split Second Box and the R4 software).
Back to the drawing board. Ugghh!
Thanks Again Mike for all the help. Outstanding service as always and outstanding products!
Joe
The greddy EU will do the same and most tuners are capable of using that program.
Old Oct 5, 2006 | 07:17 AM
Mike@Altered's Avatar
Mike@Altered
Six fuel kits left!
Old Oct 5, 2006 | 09:53 AM
97supratt's Avatar
97supratt
That looks like a great fuel return kit, I especially like the lines. Great work AAM.
Old Oct 9, 2006 | 09:09 AM
Dave@altered's Avatar
Dave@altered
I have 3 left, lets get them sold!!!
Old Oct 9, 2006 | 01:55 PM
booger's Avatar
booger
Joe
skydiver
You can run the return fuel system and the 440 injectors with the SS box .
Im doing it with 550's . I have the ECU flashed for the injectors [only ] and tune it with the SS box. I running 13 to 14.9 psi with it .
Old Oct 10, 2006 | 06:10 AM
Mike@Altered
Originally Posted by booger
skydiver
+1
Old Oct 10, 2006 | 10:17 PM
Mr_pharmD's Avatar
Mr_pharmD
I received my return line today but its missing the fuel pressure regulator. Isn't suppose to be included with the kit?
Old Oct 11, 2006 | 05:34 AM
Dave@altered
Mr_pharmD,
I am sorry that you did not recive the Fuel Pressure Reg. I have one boxed up for you and I am going to have it send UPS Over Night. I will PM you the Tracking number. Please let me know if you need anything else.
Old Oct 12, 2006 | 11:11 AM
DMK's Avatar
DMK
Originally Posted by Mike@Altered
The best way to go about this is to use the Walboro and 440cc injectors when you have the Vortech supercharger kit. This will get rid of the FMU which can be unrelaible and overdrive the injectors. With this mentioned fuel setup most of our customers upgrade to the 3.12 or 2.87 pulley (these pullies will give you much better torque and top-end power!).
You can use the Split Second box that comes with the Vortech kit to control the 440cc injectors without problem. Or, just get the Tuner Version of the Vortech kit and forgoe their fuel system all together. In this case I'd use the UTEC (or HKS F-Con Pro if you want to spend the extra $$) for engine management.
Hope this helps,
Mike,
Is there any way we can adapt your fuel pressure regulator to the Stock Fuel System without getting the whole kit? I plan on doing Walboro and 440cc for my Vortech, but want to control the fuel pressure as I have heard, the idle FP is way too high (80psi). Getting the entire Fuel Return System seems a bit much when I am going to be making maybe 360whp at most.
Old Oct 12, 2006 | 05:57 PM
skyydiver's Avatar
skyydiver
Thank you Booger...as always, you are a plethora of knowledge!
