Raised compression....
Old Oct 12, 2006 | 10:33 AM
THE TECH's Avatar
THE TECH
Originally Posted by LODOSS
any increase in compression will result in better efficiency an thus improving torque and power.
That's a pretty broad statement which in the wrong hands could lead to blowing a motor.
Old Oct 12, 2006 | 11:18 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
+1
Old Oct 12, 2006 | 11:31 AM
trey.hutcheson's Avatar
trey.hutcheson
Originally Posted by Z1 Performance
At this moment there are very few cars with properly built NA motors. Richie in Australia is the one that comes to mind as the most highly evolved that still runs pump gas and is driven regularly (I think he uses it nearly everyday in fact). There are others that are in the pipeline as well following similar directions albeit it with different components.
Do these "others" include the ghost "monster" build from that guy in Illinois?
Old Oct 12, 2006 | 11:51 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
no...not everyone with alot of work done to their cars is on the boards. However I know of several cars in the works right now with various NA setups - real cars, owned by real people
Old Oct 12, 2006 | 02:05 PM
Q45tech's Avatar
Q45tech
Lot's of difference between [fairly useless published] static compression and actual running compression [cam duration, lift- valve flow vs reversion during overlap period].
A honest way to evaluate compression effects is comparing torque creation per liter/per cubic inch.
Back in the leaded gasoline days engines were lucky to create 1.1 lb/ft per cubic inch today we get 1.2-1.25 lb/ft per ci .
Old Oct 12, 2006 | 02:17 PM
Eazzy's Avatar
Eazzy
In all due respect and correct me if Im wrong---But u cant totally compare CR with Compression---Kinda Apples and Oranges---Boy --This is going to raise a Rant !!!
Old Oct 12, 2006 | 02:24 PM
Z1 Performance
Former Sponsor
it's not apples to oranges at all (you're both saying the same thing by the way), but you're WAY over the heads of 99.9% of the people here, and, also saying the same thing as I did earlier, with the compression going hand in hand with all the other selected components, and tuning.
Back in the leaded gas days, HP was also way exaggerated compared to today's SAE standards.
Old Oct 12, 2006 | 02:31 PM
Eazzy's Avatar
Eazzy
I was just making it clear to those that may confuse the two that CR remains the same through out the life of the engine --give or take a 1000th of a point, whereas Compression decreases with milage/wear/failures etc.
Just a clarification.
Old Oct 12, 2006 | 03:31 PM
NA&CH's Avatar
NA&CH
Very good thread.
Adam can't wait to see what you have planned. I saw some specs of some sort somewhere
Old Oct 12, 2006 | 03:49 PM
Z1 Performance
Former Sponsor
wooooooaaahhhh....my boys are leaking info on me
time for a new mantra (ala Entourage) - "Silence is F'ing Golden"
Old Oct 15, 2006 | 08:19 AM
mario60185's Avatar
mario60185
Chicago Realtor
come one z1 what are you working on? I never understood keeping projects a secret anyways.
Old Oct 15, 2006 | 02:33 PM
Z1 Performance
Former Sponsor
sorry man...I'm not spilling the beans on anything until its installed and tuned you can disagree with my doing that but I have my reasons. It's been a long process and it's at the tail end now, and I just want to make sure it works as we think it will before revealing anything
Old Oct 15, 2006 | 04:09 PM
Zexy's Avatar
Zexy
Hey.. You could educate people through the process!
Old Oct 15, 2006 | 05:07 PM
Z1 Performance
Former Sponsor
not to worry - assuming everything works out as we hope it will, we'll be sharing tons of pics, dyno sheets, maybe even a video or two In due time though - we've been at work on this for while, and I'm excited to see the results
Old Oct 16, 2006 | 08:41 AM
mario60185's Avatar
mario60185
Chicago Realtor
Can you atleast give us a clue as to what your doing?
Old Oct 16, 2006 | 08:53 AM
Z1 Performance
Former Sponsor
sorry man, my lips are sealed till its completed
Old Oct 16, 2006 | 09:07 AM
mario60185's Avatar
mario60185
Chicago Realtor
Old Nov 17, 2006 | 09:14 AM
  #38
mario60185's Avatar
mario60185
Chicago Realtor
Well since z1 is mute, I thought I would share something. I popped in an old BMI video from japan last night cause the cable was out. And the esprit 350 and many others battled it out on a track. The other z's had basic bolt on mods, one was a turbo, while the esprit z had the boltons, exh., headers, computer, plus high comp. pistons, and cams.
The esprit z was great! It was taking everyone and got first place, even against one of the turbo z's. The incar view showed how it pulled like crazy in the high rpm's. Really kinda turned me on.
So in short, I will have that setup soon!
irishguy0224
Sep 22, 2015 06:57 PM
Blue350z
Jul 8, 2003 01:20 AM
Welsh 350Z N
May 16, 2003 05:21 AM
CraigW
East Canada
May 13, 2003 09:16 PM
FastEddie73
South East
26
Apr 10, 2003 12:33 PM
