How do I adjust the fan's "turn on" temp
Old Oct 24, 2006 | 08:02 PM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by 350Zteve
Here's how you can run a switch AND keep the factory turn on. Most modern car fans are controlled by the ECU allowing the fan relay to ground out. This means the fans are constantly supplied with +12v but only come on when the ECU allows them to see ground. Tap into the fan ground wire with a 14gauge wire. You must do this in the ground wire between the fans and the relay, not after the relay. Run the wire to a switch, then out the swich to ground. This will allow you to turn the fans on any time you want and if you forget, they still come on when the ECU wants them on.
A friend of mine did this with his GTP. The main reason I'm looking at the HKS Fan Controller is the lowered auto turn on for the fans (I plan to run a pair of Spal fans) and that hopefully I can monkey with the intercooler sprayer output signal to do what I want.
Old Oct 25, 2006 | 03:53 PM
Jokestrap's Avatar
Jokestrap
Looks to be only a few options here.
The car does not overheat. What I don't like about it is that it goes to 215 then back to 190 and shuts off, back to 215, then 190 and on and on. This all happens literally within minutes. So, up and down, up and down. I would really like to maintain a more consistent temp especially while at the track. I have seen the HKS fan controller and I may give it a shot. Thanks for the responses guys.
loudtoyz
Apr 6, 2023 04:52 AM
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
SharX59
Sep 27, 2015 09:23 AM
