Cooling issues
Old Dec 7, 2006 | 09:51 AM
97supratt's Avatar
97supratt
Originally Posted by KPierson
I have been checking under the radiator cap. Following the service manual it said to make sure the radiator is filled up to the overflow hose, and then fill the resorvoir up to the 'max' line. Well, I don't have a 'max' line to fill to.
Also, as stated above, I don't have a manual bleed off valve, as the APS TT eliminates it. I do believe the system is designed to bleed itself, based off of what I have read, and the fact that when we first started the car up and shut if off with the new motor and TT would could hear air escaping through the resorvoir.
I have the Nismo radiator cap.
If you don't see a max line on the reservoir I would just fill it 3/4 of it and if the system is low on coolant it should draw it in from the reservoir when it gets cold.
Old Dec 8, 2006 | 11:14 AM
sumfknguy's Avatar
sumfknguy
my reservoir was empty... I filled it up ... after about half a days worth of driving, it now stays warm on idle..
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 30, 2015 10:54 AM
