RevUp Oil Consumption TSB and discussion
Old Aug 30, 2008 | 11:46 AM
  #3441
06CPV35's Avatar
06CPV35
Originally Posted by gtstang03
Yeah i was joking about reving to limiter. Don't thint it would be the best thing todo right now. lo
Yeah it came orginally with a non rev up 287 i think it is.
LOL!! K...good to hear that
Yeah, guess 05 Base not revups. Has to be Track or 35th Anniv with 2005's.
Old Aug 30, 2008 | 12:30 PM
  #3442
gtstang03's Avatar
gtstang03
Yeah so it does look like th replaced it with the correct engine then a non rev up 287hp...
Old Aug 30, 2008 | 05:19 PM
  #3443
ZeeForce's Avatar
ZeeForce
05 Base 6mt = non revup
Old Sep 2, 2008 | 11:42 AM
  #3444
nismoZomsin's Avatar
nismoZomsin
OC TEST UPDATE: 425miles in.
I'm getting crazy idle engine noises now so I decided to take it to the dealer for a quick "check". They previously told me that I could stop-in anytime for a "checkup", but when I showed up this morning, they said that I must have driven at least 700miles before they can check it, OR if the engine oil light comes on..
–was wondering, does anyone know at what level (how many quarts), of the oil must be at for the light to come on?
Old Sep 2, 2008 | 04:06 PM
  #3445
Nismospeed4life's Avatar
Nismospeed4life
Nice to see you around from time to time ZeeForce....
Old Sep 2, 2008 | 06:12 PM
  #3446
ZeeForce's Avatar
ZeeForce
Thanks, I gotta get the stats list upudated one of these days, although I have not received any pm's with updates with the exception for about two.
Guess it's pretty dead here on peeps wanting to know how the freshly built engines are doing on oil consumption.
I will post up my used oil analysis soon, just sent off another sample.
Cheers
Curtis
Old Sep 2, 2008 | 06:16 PM
  #3447
Nismospeed4life
Cheers
Curtis
I started my OC test, so I'll keep you posted.
Old Sep 2, 2008 | 06:18 PM
  #3448
ZeeForce's Avatar
ZeeForce
kewl, thanks Nismospeed4life.
Old Sep 2, 2008 | 06:50 PM
  #3449
antennahead's Avatar
antennahead
That's one of the problems with this issue, most report that the light never comes on, or came on way to late to help, as in there was almost no oil in the engine. My V1 was down about 2 1/2 to 3 quarts and the light never came on. I knew there was a problem because the oil pressure started acting weird.
John
Old Sep 2, 2008 | 09:41 PM
  #3450
06CPV35's Avatar
06CPV35
Cheers
Curtis
PM sent with Stats.
Just sent my sample in for UOA as well.........
Old Sep 3, 2008 | 04:55 AM
  #3451
rickosae's Avatar
rickosae
Update on my new V2: 1100 mi, 4 mm loss. had its first oil change + an inspection. I noticed an intermitant metallic "snap" coming from under the car or the left front suspension when I come to a stop. I thought they forgot to tighten something, they "diagnosed it to the drive shaft or transmission. New drive shaft did not fix it so they ordered me a new tranny. Should be in for install next week. This will be the second tranny swap. I suspect the suspension but who cares its their nickel. I'm starting to flirt with the idea of a buy-back, 2 engines, 3 trannies, new head unit.
Old Sep 3, 2008 | 04:59 PM
  #3452
nismoZomsin
John
damn, was afraid of that...having the light not come on even when down to 2.5-3 quarts stresses me out. I really don't want my Z to die on the freeway during rush-hour traffic...not to mention that kind of stall causing further damage to other parts of my car
–thanks for the info^^
Old Sep 4, 2008 | 03:56 PM
  #3453
Nismospeed4life
Old Sep 5, 2008 | 05:59 AM
  #3454
cheshirecat79's Avatar
cheshirecat79
John
The engine oil warning light is not something you want to gauge your engine oil on. By the time that light has come on, you have little to no oil and you've already suffered engine damage as a result.
I had so little oil at one time on my OC revup motor that it barely drained out half a quart... no oil light.
Old Sep 5, 2008 | 06:12 AM
  #3455
4SHIZZIL's Avatar
4SHIZZIL
I had no light and a nice BOOOMB to make me realize I had chewed up 5 qts in 1400 miles of Mobile 10/30...although the 0/40 has proven very well in the VQ35DE blocks....im anti Mobil after many years of good results in other vehicles....thanks NISSAN!
New motor will never see that brand again. Pensoil Platinum Full Syn 10/30 FTW!
Old Sep 5, 2008 | 04:45 PM
  #3456
Blue_Z's Avatar
Blue_Z
I think my V2 is consuming.
Around 300 miles I checked my level and it was at 11mm. I did research on here and concluded it was probably because the nissan techs didnt put in 5.5 on the initial fill.
I filled about a half quart at this point (because that's all I had lying around) so it was somewhere around 6mm after the top off. Well now I'm a little over 1000 miles. I checked again yesterday and again this morning, I'm back at 11mm.
Old Sep 5, 2008 | 07:21 PM
  #3457
06CPV35's Avatar
06CPV35
^My V2 at 75mi used 0mm
Next 425 = 4mm
Another 1240 = 8mm
Another 2017 = 8mm
Total 3757mi = 20mm
Mine's improving it seems. Hopefully yours will too.
Old Sep 5, 2008 | 08:08 PM
  #3458
ZeeForce's Avatar
ZeeForce
Thanks 06CPV35 for the stats pm, will update and post one of these days soon.
Old Sep 5, 2008 | 08:11 PM
  #3459
ZeeForce's Avatar
ZeeForce
Default My latest Used Oil Analysis from Dysonlabs
Just got back my Used Oil Analysis from dysonlabs.......woot..woot..
Looking very nice.
I will post up the raw data on Resolute's UOA sticky for his interpretation that I can post or link to here. Will is always dialed in with dysonlabs interpretation.
This is the best I have ever seen on my engine with 11k miles on a freshly built engine. Break-in is almost finished...time to romp on it, is the word I got from the lab.
Will keep you all posted.
A Used Oil Analysis is your best friend in determining the condition and break-in of your engine.
Old Sep 5, 2008 | 09:47 PM
  #3460
06CPV35's Avatar
06CPV35
^ That means I should be getting mine back soon I hope. What was your turn-around time?
That's good news about your V2 at 11K.
