RevUp Oil Consumption TSB and discussion
Old Aug 22, 2007 | 07:53 PM
  #1361
Hexxum001's Avatar
Hexxum001
Known V2 install recipients and their results:
1) Dbasal - maybe not fixed.
2) Theatrix - not known (I've PM'd asking for results)
3) RBlover - see above
4) 4Shizzil - appears to be complete success!!!
5) Zmaximus - still consuming
6) Antennahead - still pending
7) Creationv2 - dont know yet...only 100 miles
8) Hexxum001 - G35 with V2 motor - so far so good
Old Aug 22, 2007 | 07:57 PM
  #1362
antennahead's Avatar
antennahead
Originally Posted by usmanasif
Are you aware that new engines almost ALWAYS burn oil at first while the rings and seals get fully seated and conditioned? So don't worry about "consumption" until you have some meaningful mileage on the car; just keep an eye on it and top-off as necessary.
If you are losing a large-enough amount a few thousand miles from now, only then will you have a valid cause for concern.
Yes, aware of " break-in " oil consumption. I am checking for "excessive" consumption at this point. Once break-in is over the real test starts.
Old Aug 22, 2007 | 08:55 PM
  #1363
zmedic16's Avatar
zmedic16
add me to the list of not know for sure yet... 440 miles into brake in.
Old Aug 23, 2007 | 05:26 AM
  #1364
RBlover69's Avatar
RBlover69
just give her a good break in, my last test using 0w40 synth will be my determining test. 75 dollars for that oil change so better be worth it lmao. Good luck guys, the more we knew about everything the better off we will be to solve this issue.
I was thinking wouldnt it suck to lemon the car and recieve another oil consumption Z lmao. THat wouldve been tourture lol. Probably wouldve gotten a 07 actaully. lol good luck and post updates.
Oh DB no prob man, did u switch to synth yet. Try 0w40 mobile 1 or 0w30 amsoil amazing oils so far in the vq35de and vq35der
ONE MORE THING WHEN THERE CHANGING THE OIL MAKE SURE THEY CHANGE THE Fccccking filter. I went to a place where i seen some shady **** where they charged him for the oil change poor sap didnt know about cars it seems and they changed the oil and left the old oil filter on. That sucks....dont be taken aswell. I usually ask for my old one then throw it out. Im from NYC before i came to florida this is a common tactic. Also....you guys cars are fairly new do not let them get u for clearning ur throttle body or cleaning the injectors. lata brothas lol
I actaully wanna see some revups make power so hopefully we all get finished with it and start our own thread of revups reaching 300 rwhp or modded out man. Since our engine is preety limited as is.
Old Aug 23, 2007 | 05:33 AM
  #1365
tubbed240's Avatar
tubbed240
I'm actually experiencing the oil consumption issue now. Getting ready to take it to the dealer to go through all of this also. If I hear anything different I'll be sure to post here.
No doubt about this. I know a very shady shop here in the Dumfries, VA area (Total Auto Repair & Motorsports) that does that very thing. He actually uses a sharpie and puts a line on the filter. When you have two lines (meaning you've done two oil changes) then he changes your filter. Of course he charges you for a filter each time.
Old Aug 23, 2007 | 10:22 AM
  #1366
i8acobra's Avatar
i8acobra
Originally Posted by antennahead
Interesting, some, like RBlover69 and 4Shizzil are not having consumption issues with the V2.
John
... And some people are.
yea, ...its BS. the new rings and pistons are def the trick so far. I suggest you talk to someone beyond techs. Because u will get a diff story each time.The swaps are being done on a case by case basis or else they would be replaceing cars via lemon law. All engine parts from what i know are not being supplied from new mexico but a plant in japan. Ima check the part numbers.
so far all parts look like they come from and are built in Iwaki, Japan , none of which are made or supplied by newmexico. The reworked piston and rings are the result of handbuilt engines preassmbled there and shipped here in a small number since the oil issue isnt a issue that all revup owners or S1 owners have , since the s1 and the revup are basically the same setup.
The pistons and rods that are bad aren't from New Mexico, they're from a new plant in Mexico (the country, not the state). The tech I spoke to said that his dealership has been ordered not to do ANY engine swaps. They're not evaluating on a case-by-case here in Vegas. He says Nissan NA doesn't want to keep replacing bad motors with other bad motors. They're waiting until a permanent fix can be found.
Old Aug 23, 2007 | 10:49 AM
  #1367
RBlover69's Avatar
RBlover69
Yea ther probably not been informed yet. Call corporate after getting the BB involved that will get ur case specialist changed with a more responsive rep. Then they can start have discussion of the new motors. It took awhile for me to get the ball rolling but with the florida district attorney writing me back and his secratary on my speed dial and all of us getting in contact with NNA Further channels thats how i was able to get them to get me on that list for the motor. A permanant fix was found .though it just cost nissan 10k to do it every time plus transport. And u have to be really persistant and digilent. they told me that in the beginning when our master tech here really wasnt upto date on what other dealership expierences where with this motor issue. because there all alien to eachothers doings.
Old Aug 23, 2007 | 12:00 PM
  #1368
4SHIZZIL's Avatar
4SHIZZIL
9,000 non forgiving miles since April. Not a drop lost. Just made the switch to full synthetic, ran OEM recommended until a few weeks ago.
FYI my engine was one of the lucky handbuilt ones from accross the pond.
Using Penzoil Platinum Full Syn Blend now.....cross your fingers!
Old Aug 23, 2007 | 12:10 PM
  #1369
creationv2's Avatar
creationv2
One thing i was told was to make sure that ur engine isnt a rebuild revup . because the issue will just reoccur most def. But to make sure its the V2 or the handbuilt version. U can also tell by the part numbers im told and by the bolts being silver not bronze from what my corporate rep at nissan descirbed. My engine came from japan to newyork shipped from there directly to univeral nissan in florida after making stops at jacksonville from what the manifest was told to me. None of which was ever mentioned nor described as anything given to them or made in the US for the fix for these engines.Since the problem is often replicated in just replacing a revup with a none v2 revup. They have word not to swap engine for engine, since delears are eager to do so because its almost a 10k job in this situation. To order these limted engines that are limited in supply there is actually a waiting list. I actually waited a month for mine ....and acutally knew when dbais engine came in because they told me 2 engines where shipped to florida but coming in from different ports.
hey thats some good info. by any chance were you able to also find out which bolts those are that would be changed? are tehy easily visible when opening the hood, or are they bolts that are behind or under the motor?
Old Aug 23, 2007 | 01:33 PM
  #1370
dbasal's Avatar
dbasal
I have not changed yet. My car has been sitting for a lot of time these days because I am working from home. I also read that thread on the oil results and felt it was a great thread. I was looking at the amsoil option. Last time I switched to syn, the whole thing went to you know where so I am a bit concerned doing it again, but I'll get over it and make the change.
Old Aug 23, 2007 | 03:17 PM
  #1371
antennahead
With all due respect, if they know that the pistons and rings are bad from the Mexico plant, then they know what the problem is, and shouldn't be waiting on a "permanent fix" to be found. The permanent fix IS to manufacture good pistons and rings and give us an engine with them in it.
Old Aug 23, 2007 | 04:46 PM
  #1372
creationv2's Avatar
creationv2
....about the whole silver bolts vs bronze bolts thing, does anyone know if its true? i dont remember the color of the bolts from the first motor, and when i looked at the v2 i got its a mix of a bunch of silver ones and bronze ones...
Old Aug 23, 2007 | 09:50 PM
  #1373
Bevo's Avatar
Bevo
You are really being ripped off with $75 oil change
Old Aug 24, 2007 | 04:51 AM
  #1374
RBlover69's Avatar
RBlover69
yea, its not just a oil change that brought it up to 75 but, yea prices here for a 0w40 change are in the 50s unless u do it urself.
Old Aug 24, 2007 | 03:13 PM
  #1375
Theatrix's Avatar
Theatrix
Professional
Hey guys! Out of the country at the moment and justed on for a moment. I saw the list and have to say that I haven't had enough time to evaluate yet.
I will be back in the States next Tuesday and will put some miles on.
Old Aug 24, 2007 | 04:29 PM
  #1376
ZackMax99's Avatar
ZackMax99
Checked the Oil this morning. It was low. went to Infiniti. They checked it. It was low. They kept it to do compression test. IT FAILED> 180ish in 4 cylinders and 160ish in 2 of them. He said should be 190 across all 6. So they contacted Infiniti about replacing it.
The good news is there is a Version 2 of the Reved_Up motor which is what I will get.
This is on an 06 G35coupe 6mt with 9300 miles
Old Aug 25, 2007 | 07:14 PM
  #1377
ZLOC06's Avatar
ZLOC06
Well, here's my update on my new V2 engine: Good and Bad:
Currently have 498 miles on the engine, no loss of oil, still 1/4 under H line on (wonderfully engineered) oil stick. - Good news
Took the Z to 140 mph last night on the way to the office. Checked this morning oil still good!! - Good news
BMW (w/ a passenger) passed me up (twice) like I was standing still @ 140!! What the f@#*!!! - Bad News!!
Life passes you by fast, a BMW even faster!!!
Old Aug 25, 2007 | 07:31 PM
  #1378
CESAROTORRES's Avatar
CESAROTORRES
What BMW? M6, M3, the New twin turbo 335?????
Cesar
Old Aug 25, 2007 | 07:46 PM
  #1379
ZLOC06's Avatar
ZLOC06
Talking
Cesar
Well, it was an older M3, maybe 2003-05. Two you kids. We raced for about 5 miles. I couldn't catch up to the bastards at 140, so he was gracious enough to slow down, just so I can read his license plate and smell his smoke. That just guaranteed...........twin turbo ordered for XMas!!
Old Aug 25, 2007 | 07:50 PM
  #1380
CESAROTORRES
Oh yes!!! Unfortunately the M3 will kick your butt. Now get a TT and you will kick a stock e46 M3 easy.
Cesar
