Firing Order Switcheroo
Old Dec 1, 2006 | 09:43 AM
TheLastSpartan's Avatar
TheLastSpartan
Default Firing Order Switcheroo
I was reading an article the other day about how some tuners of, for example, gen III chevy small blocks would change the firing order with the use of a different cam. Even if all the lift and duration stayed stock but the firing order was different they would gain something like 10-15 hp (depending on how good their intake was). What do you guys think about this? I'm not sure any cams out there for the Z do this?
Matt
Old Dec 5, 2006 | 10:44 PM
TheLastSpartan
no one?
Old Dec 5, 2006 | 11:02 PM
PDX_Racer's Avatar
PDX_Racer
You'd have to change more than just the cams...
...try the crankshaft as well.
(However, since it WAS posted on the Internet, it must be true!)
Old Dec 6, 2006 | 12:10 AM
MR_X's Avatar
MR_X
^you need to watch some Horse Power TV on Spike.
I only seen this working on old chevy V8s and they do gain hp and the sound is different.
Old Dec 6, 2006 | 07:06 AM
drumma022's Avatar
drumma022
I'm sure the ECU would have a fit!
Old Dec 6, 2006 | 07:38 AM
rocks's Avatar
rocks
honda motors spin in both directions, well some do.. wierd.
Old Dec 6, 2006 | 07:47 AM
TheLastSpartan
yes, that is true i believe they changed the crank as well
and yes this does work on old chevy and ford V8s but i was just curious if anyone here had heard about it, its far fetched i know
Old Dec 6, 2006 | 07:50 AM
06blueZ's Avatar
06blueZ
Well, the easiest way to test this would be to switch the connectors on the coils. I would suggest the guess and check method. Start by unplugging one coil, and switch it to another, and see how it runs...
Edit... ok with a crank change this makes more sense...
Old Dec 6, 2006 | 12:22 PM
Lawn Dart's Avatar
Lawn Dart
No, you do not change the crankshaft. Its called the 7/4 swap. You change camshafts and spark plug wire position on the distributor.
Old Dec 6, 2006 | 12:31 PM
TheLastSpartan
Yes, hes right they dont change the crank, (i was mistaken) i just read the article again
if anyone is curious i read it in one of my issues of Hot Rod March 2006
Old Dec 6, 2006 | 12:34 PM
Motormouth's Avatar
Motormouth
I might have that one. weird.
ablaine
Nov 29, 2016 10:13 AM
350z82
Oct 1, 2015 06:25 PM
