How much rwhp will stock differential hold?
I am looking forward to going FI, but before I do want to do the supporting mods myself. I have gathered good information on clutch setups. I was wondering how much rwhp will the stock differential actually hold, before you start having issues? This is defiantly a noobs question, but does aftermarket lsd units such as the Quaife strengthen the differential. Also what have you done to strengthen your drivetrain? Thanks for any help.
Rotating Components are rated in pound feet [torque] to avoid the rpm dependent math manipulation knows as horsepower.
The AT is rated at 333 lb/ft for 100,000 shift cycles, so that might be a good assumption for the dif..........surely not above 400 lb/ft with any life factor.
You always have life issues when you increase oem power, depends on how much less than 200,000 miles is acceptable............but then again you don't use 100% power continuously...............just like a stock car might fail if you did only 2,000 drag races in a row.........500 strip miles.
Very good explanation on how a differential breaks down. So I am gathering no one has put a number on where you should consider making it stronger. I guess nissan has made them bullet proof if the guys making considerable rwhp is not having issues or no one has reached that mark.
Originally Posted by losangelesZ
Yup axles will go before the differential.
All this at the track using ET Street Radials
Originally Posted by Carlitos
yeap, I broke 4 stock, 2 level 3 and now the diff with my DSS level 5.
whats next, level 10?
It is usually the clutch dumps/launches that will kill drivetrain parts. Torque during this time is MUCH greater than once you are moving.
So, the stock diff might last a long time at high torque levels if you roll into the throttle and don't drop the clutch, but it might fail on a stock car if you drop the clutch at redline with a strong clutch and sticky tires.
If you're not running slicks or D.radials they hold more than most put down on the street. Once you start limiting the wheelspin and increasing traction the torque through the drivetrain will go up exponentially.
never mind, it was axle # 7, and yes it was a DSS level 5 while accelerating in 2nd gear.
iv'e had my stock drivetrain besides my clutch and flywheel now for a month and a half.....and mine is fine......but its only been a month and a half.....hopefully it doesnt go out 4 a good while!!!!haha
As most of you know I drag race a decent amount-not so much now though. I still run the stock diff making 561ft/lbs @ high boost. I also raced my 400ft/lb TN set-up and I ran slicks with bolt-ons also. While the stock diff isnt all that great-->mine peg legs every once in a while for a few seconds during burnouts, it is a beast strength wise. Im sure with a nice aftermarket diff I could pull more consistent 60ft's and likely even lower then slightly but for the money involved I'll stick with stock for now. Ive never heard of anybody blowing the diff.
To the OP-if you go FI and dont drag race A LOT you dont even have to worry, your stock diff will hold up.
Now, what's going to fix the axles problem? maybe we should start a new thread with "what's next after level 5"
Ive read that Vinny Ten at Performance Motorsports in NJ welds the stock inner cv joints on the Level 5's, and hes had success. Of course that would be a drag only solution as Id imagine that car would hop around like a crack ***** pulling a U-Turn...
350Z_Al
Oct 29, 2020 07:44 PM
