Nismo Clutch contents
Old Dec 16, 2006 | 02:05 AM
Cloud's Avatar
Cloud
Default Nismo Clutch contents
I bought a new nismo clutch and it comes with the cover & pressure plate, 8 bolts. Did i get the correct number of bolts? Is there supposed to be a throw out bearing included?
Old Dec 16, 2006 | 03:35 AM
gringott's Avatar
gringott
I purchased mine separately.
Old Dec 16, 2006 | 03:40 AM
Eazzy's Avatar
Eazzy
TO brgs are selomly included in kits-8 should be right for bolts
Old Dec 16, 2006 | 03:49 AM
Jay'Z's Avatar
Jay'Z
I believe you are looking for this....... as it is sold separately for about 20.00..
Old Dec 16, 2006 | 03:52 AM
Eazzy's Avatar
Eazzy
That is a pilot Brg ---Not a Throw out
Old Dec 16, 2006 | 03:59 AM
gringott's Avatar
gringott
At mynismo.com part number 30402-69F10 OEM release bearing.
$28.22
Old Dec 16, 2006 | 04:14 AM
Jay'Z's Avatar
Jay'Z
my bad .. i guess i should read more when helping someone.. but this pilot bearing is still necessary .....
Old Dec 16, 2006 | 11:45 AM
Rick06Z's Avatar
Rick06Z
Old Dec 16, 2006 | 11:49 AM
Eazzy's Avatar
Eazzy
Originally Posted by Rick06Z
My Nismo clutch did not come with a TO bearing but I believe the instructions say to install a new one at the same time.
ALWAYS replace it !!!!! The pilot brg I replace if I feel it mite be bad ---For example if it is a nettle brg and is dry or if it is a sintered bronze one, if there is a shiny spot on it
Old Dec 16, 2006 | 12:40 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the pilot bushings or throwout are not included - because there really is no such thing as a Nismo clutch "kit" - Nissan sells the pressure plate and disk seperately
absolutely replace the bearing
Old Dec 16, 2006 | 07:17 PM
Cloud's Avatar
Cloud
oh crap.. installl's on wednesday and I didn't get the TO bearing. Do I need the pilot bearing for the install too?
Old Dec 16, 2006 | 08:06 PM
Z1 Performance
Former Sponsor
you should absolutely change both
Old Dec 16, 2006 | 09:37 PM
Eazzy's Avatar
Eazzy
Be best u go ahead and replace the pilot also ---I let them slide every so often but its best not to. If it is a nettle and its not prelubed, do so sparingly. If its sintered bronze, dont.
Tell u right now ---they can be a pain getting out less u have the appropiate gadgets, but no big deal
Old Dec 16, 2006 | 10:32 PM
Cloud's Avatar
Cloud
say where can i get them if i don't wanna order them through the net. only 2 business days till install and i don't want any late shipments. does the nissan dealership have them?
Old Dec 17, 2006 | 05:01 AM
Eazzy's Avatar
Eazzy
Fairly common ---Napa or even Auto Zone may have them ----They are pretty much standardized
Old Dec 17, 2006 | 05:17 AM
FirstZ's Avatar
FirstZ
it's a dealer only item, mynismo has the best prices. I would recommend changing the TO bearing and polit bearing.
Old Dec 17, 2006 | 05:57 AM
Eazzy's Avatar
Eazzy
In all due respect, I would check. It is seldom that a manufacturer will have custom built brgs. A machine is generally built to except brgs in production. Simply cost effective. Actually the brg on the throwout can be pressed off and replaced. At least chk cuz it will save u some $$$$.
I speak from experience but that dosent mean Im right.
Old Dec 17, 2006 | 10:19 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
NISMO Pressure Plate and Disc is sold seperately...
They are to be used with OE Release Bearings (best to install a new one at time of install) as well as installing a new pilot bushing...
If you are changing your flywheel or even once you remove the flywheel to install the pilot bushing, do not re-use the flywheel bolts...
sherm
Apr 11, 2020 05:21 PM
nanotech
Oct 2, 2015 05:02 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
