oil filters
Old Dec 22, 2006 | 05:59 PM
mw9's Avatar
mw9
Default oil filters
Is the oil filter for are car small. I just ordered some oil and filters from amsoil. The filter looks small, but I have never seen the size of are oil filter. Is there anyone here who uses this oil filter, #ea012. I got it from there website, they said its the right one. Just curious.
Old Dec 22, 2006 | 06:01 PM
UGOTZ'D's Avatar
UGOTZ'D
yes they are smaller in length than average oil filters!
Old Dec 22, 2006 | 09:57 PM
ZCARBANDIT's Avatar
ZCARBANDIT
The stock filter is a 65F00 from nissan, but it will take the 9E000 which is a little longer. The 65F00 is small,not sure on the amsoil num.
Old Dec 22, 2006 | 10:52 PM
//RacingSpirit>'s Avatar
//RacingSpirit>
the vq motor in the 350z shares the same oil filter as the murano, newer pathfinder, xtrail, quest.....which is a fairly small one (15208-65f00), but will take the taller filter used in many other smaller nissan motors too (15208-9e000)
Old Dec 23, 2006 | 08:49 AM
n8vz's Avatar
n8vz
You can use the 9E000 filter in your Z. It cost the same as 65F00 and has better internal design (metal end-caps) Google the topic and you can get more info. You can also use aftermarket filters like Purolators and WIX spec'd for the previous generation Maxima (VQ35DE)
Old Jan 5, 2007 | 04:26 PM
350Z_LEE's Avatar
350Z_LEE
K&n
Old Jan 5, 2007 | 04:29 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Originally Posted by 350Z_LEE
K&n
http://www.knfilters.com/search/prod...x?Prod=HP-1008
HP-1008 Product Specifications
Product Style: Oil Filters
Height: 2.91 in (74 mm)
Outside Diameter: 2.656 in (67 mm)
PSI Relief Valve: 11-17
Anti Drain Back Valve: Yes
Weight: 0.5 lb (0.2 kg)
Product Box Length: 3.15 in (80 mm)
Product Box Width: 3.15 in (80 mm)
Product Box Height: 2.91 in (74 mm)
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
