Does this sound like a Clutch problem?
Old Jan 7, 2007 | 10:44 AM
filmnews's Avatar
filmnews
Default Does this sound like a Clutch problem?
Over the last few weeks, I have noticed some problems.
1. My cruise-control shuts off whn I am going up hills.
2. Sometimes, my clutch doesn't release. I have to pull it back up with my foot. This has only happened a few times, but it is a problem.
3. When I am driving down the highway, I will speed up to pass somebody. The RPM's will jump 2,000 rpm's or so, and then come back down and catch. There is usually a 1 or 2 second delay.
Does this sound like the clutch? If so, is this covered under warranty?
Old Jan 7, 2007 | 10:53 AM
Eazzy's Avatar
Eazzy
Situations like this always give yr,milage etc
Old Jan 7, 2007 | 10:56 AM
filmnews's Avatar
filmnews
2005 16,000 miles 6spd
Old Jan 7, 2007 | 12:12 PM
filmnews's Avatar
filmnews
Anybody?
Old Jan 7, 2007 | 12:17 PM
Eazzy's Avatar
Eazzy
Can u smell it ??? If it is a clutch prob it has been abused. One prob is the pedal adjustment as far as wipping it out. I would say Yes it is time for a new Clutch ---set ur pedal afterwards. And who ever is driving it needs to rethink they're clutch habits
Old Jan 7, 2007 | 01:03 PM
filmnews's Avatar
filmnews
I purchased the car used with 12,000 miles on it.
Old Jan 7, 2007 | 01:28 PM
Eazzy's Avatar
Eazzy
I got mine at 18,000 ---I now have 55,000. First thing I did at 19,000 was replace the clutch, no big deal, I bought a used car. He blamed it on his daughter, but I saw him drive and it was just as much his fault.
Old Jan 7, 2007 | 02:12 PM
filmnews's Avatar
filmnews
Is the clutch under warranty?
Old Jan 7, 2007 | 03:32 PM
Eazzy's Avatar
Eazzy
Im not much of a warrenty Guy ---Many times I will just fix it myself and eat the cost cuz I want it done my way, not the dealers way. But someone will chime in here and if not ,I will look it up---If u have ur books it will tell u in there-----Clutchs and brakes are a grey area with warrenty at times
Old Jan 7, 2007 | 05:55 PM
filmnews's Avatar
filmnews
Anyone????
Old Jan 7, 2007 | 06:01 PM
Eazzy's Avatar
Eazzy
Let me chk----UGH
Old Jan 7, 2007 | 06:10 PM
Eazzy's Avatar
Eazzy
Power train is 60,000 or 60 months but they dont go into specifics so as to cover their ***----Clutch would be a fight. Bite the bullit and go in with a good unit
Old Jan 7, 2007 | 06:33 PM
filmnews's Avatar
filmnews
I will see what they say tomorrow. I am wanting to get the JWT flywheel and clutch anyway.
Old Jan 7, 2007 | 06:42 PM
Eazzy's Avatar
Eazzy
Thats my advice---also the ACT is a good unit from what I hear from reliable sources----( MIAPLAYA I think ) and he should know ---I run the JWT
Old Jan 8, 2007 | 11:54 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
#1. I have no idea
#2. Sounds like you could use a clutch fluid flush / bleed the clutch fluid
#3. Sounds like a bad clutch
Old Jan 8, 2007 | 04:34 PM
filmnews's Avatar
filmnews
The Z broke today. I left for work this morning, and I had a real hard time getting up to speed. The car would rev up, and then it would finally grab. I made it to Terre Haute ok, and I could smell something burning. When I went to lunch, I had a real hard time getting out of the parking lot. I drove it to Sycamore Checy/Nissan to get the clutch checked out. The mechanic came out to drive it, and he couldn't get it to move. I told him the problems I was having, and he said it was the clutch and flywheel. The manager said that this was not under warranty. He quoted me a price of $1,800 installed. That is with a new clutch and flywheel. I said ok, and went to Finzel's. I ordered a JWT lightweight flywheel and a heavy duty clutch. It will cost a little over $850 shipped overnight from Texas. They are suppose to start on it Wednesday. The light weight flywheel is 14 pounds versus 28lbs of the stock flywheel. The clutch is rated to hold over 500 pounds of TQ!!!!!!! I am not to mad at Sycamore for not supporting this under warranty because I was going to do this mod eventually.
Old Jan 8, 2007 | 04:38 PM
Kam350z's Avatar
Kam350z
You'll love the new clutch/flywheel. It'll rev much faster and it'll feel like an overall newer car while driving. Good luck with the install!
Old Jan 8, 2007 | 04:55 PM
filmnews's Avatar
filmnews
Thanks, the local body shop is doing the install for $305. Does this sound like a good price? Does the transmission have to come out?
Old Jan 8, 2007 | 06:29 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
1. can't answer
2. bleed your clutch and replace the fluid, or your master and/or slave (is there a slave on these?) might be done
3. your clutch is shot
Old Jan 8, 2007 | 06:44 PM
filmnews's Avatar
filmnews
Yeah, It was not easy to drive.
