Going NA, and I need parts with the highest HP and TQ #'s
how does picking the parts that may individually make the most hp add up to a car that makes the most hp?
you're not going to get much more from this thread than a giant list of parts that are available
Do some searches and you'll find who is making the most power with NA stuff, and from there, you can decide for yourself if you're ready to drop the required coin to make it happen.
I have about the same setup now that you are looking to get currently, I havent run the car since it has been modded... The problem with modding a car is it takes $$ which mean I have to work more. So no racing. I have raced and beaten some rides such a New GTO & C5 Auto vettes. What not but other than that no real judge on how fast I am goin.
What mods do you have? Beating a C5 is pretty good.
Im currently on this road as well .. only my goal is to get to 300 WHP and lighten the car a bit without taking out dialy functions. I can relate to the $$$ concidering everything I bought was high dollar products. Keep in mind this is not always the greatest in HP .. typically it is though. You just have to do your research for combo's that produce good numbers in correspondence to your driving.
heres my set-up so far
koyo radiator
JWT popcharger
UTR resonated test pipes
HKS titanium dual exhaust
Gutted trunk
Volk TE-37 Time Attacks
In the process of getting the following-
Crawford headers
Cosworth Plenum (when it comes out)
JWT or Nismo cams
Valve springs/ retainers
0.7 mm head gasket
Koyo radiator
This set-up with a good tune and some weight reduction will be a very fun N/A Z to drive. I just dont want to go FI .. Ive always liked the driving experience with a built NA car. I believe it is much more consistant and reliable. Know that you will not have the fatsest car out there and it will cost you high dollars and your fine. This set-up will also be very rewarding at the track for me. Good luck and Ill post dynos and pictures as soon as I have some.
koyo radiator
JWT popcharger
Gutted trunk
Crawford headers
JWT or Nismo cams
0.7 mm head gasket
Koyo radiator
3.9FD new VLSD
JWT clutch & FLywheel
PNP TB & K&N drop in
Stillen TP, Injen True Dual
Reflashed ECU, grounding kit, stripped rear area, braille battery 11.5.
Apexi N1 Coilovers & 350Evo suspension parts
Soon will have a nitrous kit until I have enough $$ to get a FI kit.
Nice setup!
3.9FD new VLSD
If money is no object...
Headers: Crawford, maybe XERD (?)
Exhaust: Borla (True-Dual)
Intake: JWT Pop-Charger
High Flow Cats: Labree Test Pipes
Spacer: Motordyne 5/1
Light Weight Crank Pulley: Skip this.
Cams: Tomei.
Tune: UTEC
I'd also consider rims that are relatively lightweight and wider for some fatter tires and the 3.9 gears. All that tuned might get you into high 12's.
Cams: Tomei.
Tune: UTEC
why skip the light weight crank? Even though it doesn't add HP it will definitely help acceleration. Just like why people would get lighten clutch and flywheel or even shorter gears. True, lighten crank pulley wont make a day and night difference but like with all NA build ups, everything little thing counts. I'm sure with a lighten crank along with lighten clutch and flywheel and shorter gears your car will accelerate like mad.
FYI: not too many have been able to hit the 300+ mark however people who have, have done extensive internal work. Basic bolt ons with cams and tune can get you real close to the 300 but not quite there. Most people who wanted to go NA eventually went with FI because the fact that the amount of money they spent could just double the power with a charger or turbo like stated previously. I did read that you want to stick with an NA setup and i agree with Z1auto, define what you really want and do some search around to get an idea how some people were able to hit the 300 mark. Just asking the board will get a list of parts you can get which is a good starting point but its not a solution.
I think that it will cost around $6,000.
$1,000 - Exhaust
Motordyne Spacer and MREV2 - $800
Intake - $280
Headers - $800
Pulley's - $400
High Flow Cats - $400
UTEC - $700
Cams - $1,300
Gears - $750
Rough Estimate = $6,400
$1,000 - Exhaust
Intake - $280
Headers - $800
Pulley's - $400
UTEC - $700
Cams - $1,300
Gears - $750
Here is what it cost me to run 13.1 @ 107mph.
Pop charger - $100
Crawford Plenum - $450 (back in the day original with welds, now $350)
Kinetix test-pipes - $200
Injen exhaust - $750
UR crank pulley - $210
Technosuare ECU - $600
Slicks/drag wheels - $450
My total = $ 2760. If you copied this exact it would now cost you $2660 because the plenums are now cast not welded like they used to be. I gained 23whp over my stock dyno and my car ran very strong NA. If you need more than that to run low 13's or 12's your doing something really wrong.
Ending power--> 262whp, 252ft/lbs Dynojet, 5th gear, SAE corrected.
Pop charger - $100
Pop charger - $100
Pop charger - $100
Pop charger - $100
Pop charger - $100
BTW, If all you need is basic bolt ons to get low 13's then the simplist solution would be to I/E the car, and NOS the thing. As stated above several of the major bolt ons only gets you 30whp or so if you added cams. Most small nitros kits will easily add 30+whp. Nitros is not my thing but it's the quickest cheapest way to temporary modest power increases at the dragstrip. Of course it all depends on your view of Nitros as it is a "power adder" but not boost per say.
i have:
utec $799
pulley set $200
lebree resonanted tp $ 150
custom hks dual exhaust $1000
popcharger $ 120
strup headers $ 265
md 5/16 spacer $ 260
jwt clutch & flywheel combo $575
lsd $ 400
sun automobile hyperforce voltage system: $275
custom ground wire kit: 30
final hp 270whp & 250tq
total spent n/a: 4074
just so you know i got most of my mods used!!! thats where i saved alot of money$$$
It hurts me to say that i could have gone FI but i chose not to cause i need this car to be reliable as possible since its my only means of transportation.
Overall im very happy with the way my car performs, i gained over 30+whp & 20+tq.
utec $799
pulley set $200
popcharger $ 120
strup headers $ 265
lsd $ 400
Originally Posted by 98sr20ve
Just curious what engine you have? I have been looking for RevUp stuff and it seems far and few between.
For those that want to see it, NA runs. Notice/listen the first run I come off at idle and still run 13.5 @ 106mph...
