loud screeching engine noise... HELP!
guys, I really need your help. I was trying to install the plenum spacer and I got about half way into it when the sun went down. So, I put everything back together (never even had a chance to install the plenum).
When I was done putting everything back together, I turned on the car and it started screeching real loud. The idle was low and if I didn't gas it, it would die.
I figured that it might be something with the air intake because it was coming from under the stock intake tube but nothing was loose.
Can anyone help? I live in Alhambra and if someone is local, I'll give you some cash to help me fix whatever it is that I screwed up.
Help
Help
sorry, I am really stressed out...
Earlier tonight I tried to install the plenum spacer. I removed the strut bar, removed the upper plenum, and removed the air intake but the sun started to go down. Instead of going any further, I figured that I would just do it another day so I reinstalled the air intake, the upper plenum and the strut bar.
Before I went back into the house, I turned on the car and it started to screech very loud. I got out to see what was wrong and the screeching was coming from under the air intake, but nothing was lose.
I go to school 25 miles from home and I work about 30 miles from home so I need my car up and running ASAP or else I am screwed.
I really need your guy's help right now. What do I do?
MAYBE ----In ur messin around u c=just ran the Battery down and ur alternator is working its *** off to charge it back up and because of a Worn/loose belt , U are getting belt squeal---Chk ur belt, make sure it is good AND VERY tight
I checked all the connections and everything is connected. And the battery was disconnected while I was working on the plenum so I don't think that it has anything to do with the alternator. I wish I had my camera here so that I could record a clip of what it sounds like. frustrating!
similar thing happened to me. Make sure the plenum is laying completely flat and there is nothing in between. In my situation, i was hearing a whistling sound while the car was on, turned out to be a piece of metal lodged between the plenum and the metal piece it sits on.
Guest
Posts: n/a
Sorry Im New To The Forum.my Name Is Frank And I Am The Service Manager At West Covina Nissan.if Your Car Is Still Giving You A Problem Lets See About Getting The Car Into The Shop As Soon As Possible And See If We Can Get That Taken Care Of For You.dont Stress Out To Much,it Doesnt Seem Like It Could Be Anything To Drastic.(626)732-1000
You probably didn't seal everything right. Maybe it's an exhaust leak? You got a torque wrench right? Torque everything back according to what Motordyne says in their instructions. Becareful not to over-torque and in the order shown. You should be alright.
liqalu04
Jan 2, 2022 12:58 PM
