How hot is the engine bay?
Old Feb 12, 2007 | 09:16 AM
blap0220's Avatar
blap0220
Default How hot is the engine bay?
Do any of you know how hot an engine bay can get? Particularly around the intake? What temperature? I put some dynamat (rated at 350F, 175C) on the pop charger's heat shield to improve its purpose. It works by the way. But i'm afraid the dynamat might not be rated high enough to withstand the engine bay temps. Can anyone advise? I live in Texas where it's HOT!
Thanks,
Old Feb 12, 2007 | 10:45 AM
davidf's Avatar
davidf
It should be fine there since your far from the manifolds and when your driving theres constant air flow in that spot.
Old Feb 12, 2007 | 11:48 AM
Shift_Z33's Avatar
Shift_Z33
I doubt it will hurt anything, although I doubt it would help either.
Old Feb 12, 2007 | 11:54 AM
6894kevin's Avatar
6894kevin
Kind of on the topic of heat, and kinda not directly on this topic. Bu I will ask anyway, has anyone ever louvered there hood. It was real big way back in the day with hot rods and was just wondering is anyone has ever seen a z with hood louvers.
Cheers
Kevin
Old Feb 12, 2007 | 01:19 PM
blap0220's Avatar
blap0220
Wouldn't this help to prevent power loss due to heat though? I'm sure that that chamber where the intake is will be cooler now.
Old Feb 12, 2007 | 03:18 PM
cubu's Avatar
cubu
air moves in and out too fast to make a difference, plus the heatshield isn't air tight
Old Feb 12, 2007 | 03:22 PM
KuraiShimo's Avatar
KuraiShimo
well I believe my teacher told me last year that the inside of the engine operates at 4000F, which is why the cooling system/firewall/heatshield is there.
Old Feb 12, 2007 | 03:30 PM
jtabraham's Avatar
jtabraham
You're teacher was wrong...aluminum melts at about 1200F
Old Feb 12, 2007 | 04:22 PM
VIZAGE's Avatar
VIZAGE
Somebody is smarter.
Old Feb 12, 2007 | 05:59 PM
bofa's Avatar
bofa
^Mm-Momma said...
Old Feb 12, 2007 | 06:01 PM
jtabraham's Avatar
jtabraham
You're wrong Colonel Sanders
Old Feb 12, 2007 | 06:48 PM
KuraiShimo's Avatar
KuraiShimo
oh maybe it was 400...haha whatever.
Old Feb 13, 2007 | 06:26 AM
Q45tech's Avatar
Q45tech
Radio Shack has inexpensive outside [15-20'] wired digital temp gauges, great to mount sensor underhood or in air path to see the horrible performance of most cone filters even with INSULATION...........especially compared to oem system.
All that counts is inside plenum temperature.
The MAF assembly has an IAT sensor that can be read from OBD2 scanner/data monitor.
For every 11F temp rise the density and power output drops by 1%.
Consider in summer that the rad raises temp by 20-30F and AC condenser by the same amount........not unusal to see 160F air flowing into a cone.
Old Feb 13, 2007 | 03:03 PM
blap0220's Avatar
blap0220
well, I checked the dynamat. and it melted. I took it off. I don't recommend anyone try what I did. Go with thermotec stuff
Old Feb 14, 2007 | 01:25 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Your car gets the hottest when it's idling.
When you're driving around, the engine bay is only slightly hotter than ambient temperature.
Get a meat thermometer ($5, grocery store) and zip-tie it somewhere inside your engine bay. Then let it idle for like 10 minutes, and check the temp.
Old Feb 14, 2007 | 03:49 PM
Cannysage's Avatar
Cannysage
My bay is unnaturally hot.. you can roast an aged, new york prime rip or ribeye... I've been keeping my eyes on the gauges..
Old Feb 14, 2007 | 04:59 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
fast cars and steak ftw
Old Feb 21, 2007 | 04:05 AM
tooskerdo's Avatar
tooskerdo
My engine gets so hot that i have to open the hood after i drive it. And when i come back into the garage after 1/2 hr. it's like an oven. (could possibly be the blower) but i know it gets HOT.
Old Feb 21, 2007 | 05:57 AM
Jun's Avatar
Jun
How does dynamat improve the purpose of the heatshield? Does it keep it cool or something? I thought it was just sound-deadening material.
Old Feb 21, 2007 | 07:10 AM
mikead_99's Avatar
mikead_99
I think it is being used to close off the gaps in the back. That makes sense anyway.
