Plenum spacer causing oil loss??
Old Feb 16, 2007 | 06:06 PM
halfass872's Avatar
halfass872
Default Plenum spacer causing oil loss??
I've researched all up and down trying to decide what spacer to get. While at the Nissan dealer today i was talking to their head mechanic (also a Z owner) he said he didn't recomend the spacers cause he has had a handfull of Z's, rev-up and non-rev up, come in with oil loss issues after installing plenum spacers?? Now i have not seen a single post here to back that up, but on the other hand i have known this individual for quite a while now, and he knows his stuff pretty good. So i don't know what to believe, and i'm a little crushed 'cause next week i planned on buying the Kinetics Upper plenum. Any comments??
Old Feb 16, 2007 | 06:15 PM
DavesZ#3's Avatar
DavesZ#3
I don't see how that would be possible. Only air flows through the plenum. There is nothing to connect it to any of the oiled part of the engine. The only oil it gets close to is the vapor that is drawn back into the intake via the PCV valve.
Old Feb 16, 2007 | 06:17 PM
halfass872's Avatar
halfass872
I agree! The only down side of this mod i know of is that i've heard it makes you run a little lean. Would that cause oil consumption??
Old Feb 16, 2007 | 06:21 PM
Ilov350ZEE's Avatar
Ilov350ZEE
maybe cause of stepping on the gas more
Old Feb 16, 2007 | 06:24 PM
You got me. If the mechanic would post an explanation here, I sure would like to read it.
Old Feb 16, 2007 | 06:30 PM
Eazzy's Avatar
Eazzy
Thats a typical statement comeing from a "head" Mechanic now days----He's full of ****
If they are losing oil, Its not becuse of the spacer. Thats like sayin ---Jeez, my clutch is slipping, must be that new air cleaner I put in.
Old Feb 16, 2007 | 07:02 PM
halfass872's Avatar
halfass872
Normally i'd be the first to agree with that. Only reason i gave it a second thought is because he has always helped me out, gave me alot of freebies, and never tried to tell me any outrageous things were wrong with my Z. (after 3 trannys and two clutches under warranty in the past 9 months) But you do have a valid point. All i can think is it was a coincidence, and they were just poorly maintained and rev-up oil eating motors.
Old Feb 16, 2007 | 07:04 PM
Question
Would like to see a before and after air:fuel ratio chart. Thanks.
Old Feb 16, 2007 | 07:17 PM
TayTaythatsme04's Avatar
TayTaythatsme04
sounds like a dealer that doesnt want to replace you engine for eatting oil, and he is trying to put the problem on the spacer
Old Feb 17, 2007 | 01:00 AM
Cannysage's Avatar
Cannysage
when you smash-in the oil pan with a plenum spacer in your hand, you may lose oil.
Old Feb 17, 2007 | 03:44 AM
Eazzy's Avatar
Eazzy
+1000 ---- Iv done that --- What a mess !!!!!!
Proceed with confidence with ur new spacer----Personally I'd recommend a Motor Dyne ---Good Luck
Old Feb 17, 2007 | 04:18 AM
halfass872's Avatar
halfass872
LMAO!!!! Ok thanks guys!! Kinda what i was hoping to hear, lol.
Old Feb 17, 2007 | 10:33 AM
VIZAGE's Avatar
VIZAGE
Why do when we here the dumbest crap ever, it always comes from a mechanic from a dealership? You sure his gasket is sealed?
apex locator
Jul 23, 2021 02:27 AM
_bit
Oct 2, 2015 07:49 AM
