what happened here??
I have an 06 auto non-revup .Today I had plenum spacer installed at AAM with their angled spacer i must say its really worth spending $370 i noticed the gain. Now something bad happened not really sure what it is, where its coming from or if it is connected with the spacer. When i accelerate from stop i hear some grinding noise sounds like from the transmission and it only happens when i step on the gas hard. I did a couple of hard acceleration from stop after the spacer install, then the problem occured. Does it sound like tranny problem maybe on the 1st gear? Will this be covered under warranty, i have only 6k miles?
it should be all covered under warranty..........but the dealer will try to blame any after market mod as the problem.just tell them about the mossmagnussun act and they will cover it as the plenum has nothing to do with nissan,s junk transmissions.
i thought 350Z auto tranny is well built it can handle mild abuse.
i only did 2 hard acceleration in a row and this happens.
If this is not the tranny i would guess its the torque converter
Make sure your strut tower brace isn't contacting your plenum. This will cause a vibration, and maybe even a noise as the vibrating engine would contact the brace under hard acceleration. Keep in mind there will less clearance between the two in a hot engine bay because of thermal expansion.
|dg
Did they do the install? Better hope they didn't drop a bolt down your engine....
but if that isn't the case, then something else is up. Kinda sucks that it happened after your engine mod.
Originally Posted by Ilov350ZEE
whats mossmagnussun act ?
