Engine turned off !! urgent help
Old Feb 17, 2007 | 10:47 PM
thrillseekser's Avatar
thrillseekser
Default Engine turned off !! urgent help
Was tracking my car yesterday,
suddenly after the long straight, preparing to get into the corner,
the engine switched off, had to quickly gear jump start it,
happened only once
had a 1/2 tank of fuel, plenum spacer and straight pipes.
what could be the cause of this problem ?
i'll be tracking my car again next week,
want to know why or else i'd cancel that, it was scary trying to stop @ 200 km/hr .
Old Feb 18, 2007 | 12:08 AM
thrillseekser
Does the Z come with automatic engine cut off on low oil pressure or supply?
could that be the reason ?
or is it fuel pressure drop ? engine is NA though,
Old Feb 18, 2007 | 12:14 AM
VN_350z's Avatar
VN_350z
were u coasting ur car entering the corner??
Old Feb 18, 2007 | 01:09 AM
thrillseekser
I was going on the straight, preparing for the corner, here i applied the brakes (dashbord lights flashed and here the engine cutoff) - i managed to slide the car (with no brakes thank god for coilovers) - put it into 4th and gas ..(gear jump start)
Cloud's Avatar
Cloud
thats pretty dangerous if he was doing that...
Old Feb 18, 2007 | 01:46 AM
thrillseekser
i know it was dangerous, Thank God i was able to act quickly,
but i want to know what prob. caused my engine to stop and put me in this situation ?
any ideas guys ?
Old Feb 18, 2007 | 07:28 AM
peptidbond's Avatar
peptidbond
Some people have seen this before after installing an intake. Usually, they report it happening after a WOT run on the highway or exiting the highway onto an entrance ramp.
In both cases, they come off the gas and coast for a moment. The RPM falls and then the engine stalls. I forget what the cause is, but I want to say it is a vacuum issue. Again, if I recall correctly, they typically will have a small intake leak after installing the new hardware.
Is your plenum spacer new? Did you use new gaskets? Just curious.
Again, I could be wrong, but this sounds familiar to me.
Old Feb 18, 2007 | 10:31 AM
VN_350z's Avatar
VN_350z
this is a common problem with installing intake & plenum. Nothing to do with leak. It has something to do with MAF sensor is confused with new intake or plenum. Try to reset ECU.
I have same probleem after installing HKS intake. The problem gets better with Pop charger. That's why i've never coast my Z anymore
Old Feb 18, 2007 | 11:43 PM
thrillseekser
yes plenum spacer is new
and all gaskets are new,
so resetting the ECU should fix this issue ?
and can someone please confirm wheather or not the Z come with automatic engine cut off on low oil pressure or supply?
maybe i just need a race oil pan ?
Old Feb 19, 2007 | 12:02 AM
wesismyhero's Avatar
wesismyhero
with an aftermarket intake, the maf reads that more air is coming in than what it is designed for, thus thinking a leak, and shuts the engine down to prevent damage. the dealer called it "flooding the maf"
i have the hks rs suction kit and i had this problem. took it apart and tightened all the clamps down, now it works fine.
Old Feb 19, 2007 | 12:40 AM
thrillseekser
thanks wesismyhero.
I hope in my case resetting the ECU helps,
by the way would a A/F controller help as well ?
Old Feb 20, 2007 | 05:52 AM
thrillseekser
Today i discovered my engine has 1 liter of oil consumed !!
would a A/F controller help in stooping the MAF from stopping the engine !?
does it bypass the MAF ?
or corrects the ratio ?
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
