Z1 Motorsports clutch and ultra light flywheel
Old Feb 20, 2007 | 12:09 PM
  #41
MAC-G35's Avatar
MAC-G35
Originally Posted by MIAPLAYA
What mods were on the car for this dyno? Notice how different the torque looks from the current one? I still don't see gaining that much power from just a flywheel..
The dyno sheet you are looking at was stock + Injen CAI. Since then, I have added test pipes and Kinetix V+ plenum.
Brian
Old Feb 20, 2007 | 12:14 PM
  #42
MIAPLAYA's Avatar
MIAPLAYA
Brian
Hmm, it would be nice if they did both "flywheel" runs with the same scaling on the graph...
Old Feb 20, 2007 | 12:25 PM
  #43
sentry65's Avatar
sentry65
the burninator
scaled...
I still don't think this is an accurate power gain though. Something else is coming into play - engine temp, A/F ratio, tune, ambient temp/humidity, ECU timing map, reset ECU, maybe the first run had the AC turned on, dyno's correction factors, possibly the new fluids made a 1-2 hp difference, etc
Attached Thumbnails Z1 Motorsports clutch and ultra light flywheel-flywheel.gif
Old Feb 23, 2007 | 02:07 PM
  #44
Byang's Avatar
Byang
Is it possible to gain hp from a clutch?
Old Feb 23, 2007 | 02:18 PM
  #45
97supratt's Avatar
97supratt
Absolutely not!
Clutches increase clamping force as in hold more torque but never "Add" power, ever!
Old Feb 24, 2007 | 09:51 AM
  #46
Armitage's Avatar
Armitage
I was also under the impression a flywheel does not add HP, much like a final drive. It just free's up the engine to make power more effeciently.
Old Feb 24, 2007 | 12:08 PM
  #47
ekim81's Avatar
ekim81
Originally Posted by zman1910
Where in the world did you get the math from? Your basically saying there is a 50% drivetrain loss...when in actuality its probably less than 20%
23whp X 1.20 (or 120%) = 27.6 crank hp
if you're assuming 20% drivetrain loss, the math should actually be:
23whp/0.8 = 28.75 crank hp.
Old Feb 24, 2007 | 02:58 PM
  #48
MoodDude's Avatar
MoodDude
Great job by the Z1 crew for developing a truely useful upgrade!
A lightweight flywheel will not show its true potential on a dyno, it shows it when you drive. Here are a few quotes from Carroll Smith:
"In order for the race car to accelerate the engine must accelerate. ... In low gear the energy required to accelerate the racing engine components can approach thirty percent of the engine's dyno output-trailing off to something less than eight percent in high gear....So what do we do about it? Within the bounds of sanity, the biggest single improvement that can be made in this department is to reduce the mass and the moment of inertia of the flywheel and clutch assembly."
What he is basically saying is that you will feel more gains from the lightweight flywheel in the lower gears than you will in the high gears. Since the dyno is taken in a high gear - it will not show the true benifits. Therefore, dyno's are not the right place to judge a flywheel, you need to take it to the track and test the differences.
Uriyo_
Sep 8, 2021 08:46 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
