Oil Change - oil well over full?
Old Feb 24, 2007 | 11:17 PM
Cannysage's Avatar
Cannysage
Default Oil Change - oil well over full?
my exhausts are off and I did an oil change today. I don't want to start the car to have the oil settle in and it's reading at well over full (I hate the damn dipstick, and I checked it about 10 times). I'm getting a bad reading right?
Old Feb 25, 2007 | 05:44 AM
failsafe306's Avatar
failsafe306
How much did you put in, and did you change the filter as well?
Old Feb 25, 2007 | 06:02 AM
Jay'Z's Avatar
Jay'Z
Doesnt it require 5 quarts, +1 on the dipstick from hell......................... i bent it the other day....... POS!
Old Feb 25, 2007 | 06:44 AM
stein's Avatar
stein
I'd think you'd need to let it run a bit to get oil into the filter and which will lower the oil in the pan.
Old Feb 25, 2007 | 09:15 AM
halfass872's Avatar
halfass872
+1 on garbage dipstick!
Old Feb 25, 2007 | 09:42 AM
Cannysage's Avatar
Cannysage
yes, I changed the filter, ofcourse, and I put 5.5 quarts in.
Old Feb 25, 2007 | 10:02 AM
plumpzz's Avatar
plumpzz
Do you have an oil pan spacer?
Old Feb 25, 2007 | 10:46 AM
Bevo's Avatar
Bevo
VQ35DE is recommanded with 5 qts, the max is 5.1 qts... I think you did put too much oil in there.
Old Feb 25, 2007 | 10:48 AM
gNaRKiLL's Avatar
gNaRKiLL
Yeah its 5 quarts you put too much in I just had it done.
Old Feb 25, 2007 | 01:37 PM
Cannysage's Avatar
Cannysage
ah man, I've always thought it was 5~5.5? are you guys sure about 5 quarts? I don't have an oil pan spacer (I desperately need one, though) and I have an oil catch can.. oil catch can drains with the engine oil, right?.. wonder if it works as an extra oil reservoir...
Old Feb 25, 2007 | 01:49 PM
zstreet86's Avatar
zstreet86
the manual states its 5 quarts with a filter change. if you put to much oil you are asking for a leak to be forced out somewhere causing problems you dont want
Old Feb 25, 2007 | 01:50 PM
zstreet86's Avatar
zstreet86
at least it is for the non-revups
Old Feb 25, 2007 | 02:39 PM
failsafe306
Guys, don't forget he's running the APS oil pan which holds an extra quart. 5.5 sounds about right for the APS kit.
Just start it up and run it for a few seconds, even with the exhaust off. It won't hurt anything, just sound super cool . Then give it about 15-20 and check it again. It should just come up to the LOW mark on your stick.
Old Feb 25, 2007 | 02:48 PM
farobaba's Avatar
farobaba
tell me about it right? That damn dipstick! Everything is perfect, but they mess up the dipstick
Old Feb 25, 2007 | 03:15 PM
gNaRKiLL's Avatar
gNaRKiLL
I thought he just said he's not running a spacer or anything?
Old Feb 25, 2007 | 03:19 PM
Jay'Z's Avatar
Jay'Z
+1 he said no spacer=.5 quarts too much...... Your drowning your beast....
Old Feb 25, 2007 | 03:27 PM
Cannysage's Avatar
Cannysage
wait a minute, aps TT comes with the oil pan, now I think about it, so I'm good
I'm losing my mind, cuz I was staring right at it..
Old Feb 25, 2007 | 07:34 PM
gNaRKiLL's Avatar
gNaRKiLL
allllllrighty then!
Old Feb 25, 2007 | 08:59 PM
Kwame's Avatar
Kwame
Oil catch cans do not drain with the engine oil.
Old Feb 26, 2007 | 07:39 AM
Netko350Z's Avatar
Netko350Z
Don't worry at the rate the VQ burns oil you will be ok in 10 miles...
apex locator
Jul 23, 2021 02:27 AM
_bit
Oct 2, 2015 07:49 AM
