"Thumping" with auto shifting?
Old Mar 5, 2007 | 01:20 AM
Pooplet's Avatar
Pooplet
Default "Thumping" with auto shifting?
When Im using the triptronic I get sometimes get a transmission shift thump when I shift to third. I shift without dropping off the gas as intended...anyone else have this issue?
Old Mar 5, 2007 | 06:57 AM
Ghost 350z's Avatar
Ghost 350z
its normal
Old Mar 5, 2007 | 07:03 AM
nothingremains's Avatar
nothingremains
yea it seems normal, mine only does it about 40% of the time now
Old Mar 5, 2007 | 09:35 AM
Pooplet's Avatar
Pooplet
cool good to know..thanks
Old Apr 18, 2007 | 12:31 AM
350Z84's Avatar
350Z84
You know its a good thing I was searching. I was actually searching for a different reason, but my 06 does this same thing. Pretty much everytime I go into third. I'm glad to hear I'm not the only one. Does anyone know what causes this?
Old Apr 19, 2007 | 01:37 PM
ssgohan434's Avatar
ssgohan434
^ has something to do with 1st and 2nd gear being variable gears, and 3rd becoming fixed.
Old Apr 19, 2007 | 04:14 PM
rcdash's Avatar
rcdash
variable? fixed?
You mean locked? The torque converter does not lock till 4th and 5th gears and only above a certain speed...
Old Apr 19, 2007 | 05:45 PM
ssgohan434's Avatar
ssgohan434
I hope Aggro_Al doesn't mind me pasting some info from one of this old posts.
"The Nissan 5AT is a torque converter based performance tranny. The tranny is a real -time learning and adaptable transmission. The jolt you feel is mainly caused by two things and to a small degree the locked/coupled gear ratio difference between 2nd and 3rd gear.
The first thing that causes the jolt is the speed at which the 5AT shifts. If it detects that you are performance driving it will adapt it's shift speed to it's fastest setting and to the learned drivers style. This shift can happen faster than a blink of an eye. The Porsches do it in <200ms (yes, those are milliseconds) and the Nissan 5AT is very similar to that transmission which leads me to believe they will be in the same neighborhood. A human eyeblink is ~300ms for reference and a pro NASCAR driver can manually shift in ~0.7-0.8s.
The biggest reason for the jolt while in WOT is torque multiplication. You will get an instaneous boost in torque at the shift. The shift happens so fast that the tranny will have the ability to use more of it's torque multiplying ability. Torque multiplication is when the tranny outputs more torque to the driveshaft than the engine torque that is being input into the tranny. Many people think in error that a torque converter loses power. A torque converter actually has the ability to create more power to the driveshaft than what the engine alone is outputting. When the impeller (engine side) is spinning faster than the turbine (driveshaft side), like when you are at WOT and shifting, the stator will return excess fluid back to the impeller where the engine has an oppourtunity to re-accelerate the unused fluid to create more torque. The stock Z can almost double the engine torque some pro drag vehicles have 4x & 5x torque mulipliers. As, the fans get closer together in speed the stator gradually reduces the energy return to allow the fans to couple or lock.
The next thing that can cause a jolt is the the difference that the coupled 2nd gear ratio to the locked 3rd gear ratio makes. It's a pretty good size jump. But, because the 5AT uses a torque converter it has the ability to variably gear down to make that difference less then gradually return to the locked gear ratio.
On the 5AT, 1st, 2nd & 3rd have the ability to torque multiply. 4th gear and 5th gear are full lock-up gears. 4th and 5th gears use a mechanical clutch and don't use fluid coupling or fluid torque flow. You don't feel the jolt as much in 4th and 5th because they act just like the gears in a regular MT. They will not use fluid torque multiplication."
Old Apr 19, 2007 | 05:49 PM
Dozer's Avatar
Dozer
Wow that was really good info to know... Thanks
burglapfd
Dec 6, 2020 01:04 PM
sherm
Apr 11, 2020 05:21 PM
Jambo016
Sep 16, 2016 01:08 PM
_bit
Oct 2, 2015 07:49 AM
