Auto trans fluid
Old Apr 4, 2007 | 04:30 PM
dTor's Avatar
dTor
Originally Posted by DavesZ#3
All the dealership will have to prove is that you didn't follow the required fluid (Nissan J-Matic) usage. Or they can claim that you didn't have it serviced regularly.
+1
You void the warranty on the tranny, or any other part of the car for that matter, by not following the mfrs service directions and schedule.
Old Apr 4, 2007 | 05:18 PM
DavesZ#3's Avatar
DavesZ#3
Originally Posted by IP05G35
Nissan J-matic isn't some magical transmission fluid, it's a fluid that meets a certain spec. If an ATF meets or exceeds that spec, which Amsoil ATF does, Nissan/Infiniti can not void your warranty.
Please read post #4 of this thread carefully.
If you look in your owners manual or maintenance manual, every fluid except for one includes the phrase "or equivalent" or lists a standards-body specification (API, SAE, DOT). Nissan J-Matic is the only one that doesn't include that "or equivalent" exception.
You can argue the point till the cows come home, but if you show up at a dealership with a failed auto trans, the bottom line that they will hold you to will be "use of non-approved ATF" as the cause of failure.
Old Apr 5, 2007 | 07:23 AM
MardiGrasMax's Avatar
MardiGrasMax
Agreed. I will use J matic until the waranty on my G expires. But after that any fluid that meets the secifications of J matic will be fine and I'd prefer Amsoil over J.
Old Apr 29, 2007 | 05:46 AM
Minda's Avatar
Minda
I did experiment with Motul synth ATF (can't remember particular type), which I thought was supperior to anything. It was not good - the tranny shifts were rough and kind of slow. Nissan Matic J seemed much more fluid and thin, it smoothened the tranny a lot.
Old Apr 30, 2007 | 09:34 AM
Lem's Avatar
Lem
hmm excuse me for being a noob but how much j- matic fluid do we need? just one botttle?
Old Apr 30, 2007 | 10:15 AM
SpeedRcr's Avatar
SpeedRcr
couple of quarts if you are doing a flush refill
Old Apr 30, 2007 | 11:02 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Top 100 questions thread shows how much fluid you need for various purposes on the 350z.
link is in my signature.
Old Apr 30, 2007 | 07:11 PM
Lem's Avatar
Lem
alright thanks guys for the help
Old Sep 10, 2007 | 10:37 AM
ATL_Red_G35's Avatar
ATL_Red_G35
Update:
I'll be running AMSoil ATF on my G35. After seeing many Infiniti and Nissan dealers now using BG ATF as the J-matic replacement, I don't see the reason of not to use the AMSoil ATF. I'll report back if there's anything wrong
My car is now at 63K miles.
Old Sep 10, 2007 | 11:36 AM
Q45tech's Avatar
Q45tech
JATCO provides a warranty to Nissan which provides the warranty to you.
JATCO will not warranty the tranny to Nissan if on their inspection non J matic is found inside.
JATCO is forcing this restriction on Nissan, thus no equivalent.
The problem is the stick/slip curve on the new dual lockup clutches..........anyway problems don't usually show up until just after 100k unless you increase the torque above specified limits [333 lb/ft on input shaft].
burglapfd
Dec 6, 2020 01:04 PM
Jambo016
Sep 16, 2016 01:08 PM
_bit
Oct 2, 2015 07:49 AM
