Engine upgrade VQHR
Old Mar 18, 2007 | 02:27 PM
spiderZ's Avatar
spiderZ
Default Engine upgrade VQHR
Is there anyone knows if it is feasible to buy an upgrade kit to modify a 2003 VQ35 to VQHR? I'm really interested to know if there is an existing nismo kit or something similar on the market today for track application. The Z would need to rev higher on corner exit on the track. The added 20 hp would also be great.
Thx
Old Mar 18, 2007 | 02:30 PM
savvy's Avatar
savvy
The new engine is 80% new internals, not to mention you need a new hood to clear the dual TB's. You would be better off selling your car and buying an 07
Cux350z's Avatar
Cux350z
hatersgonnahate
nope, and its not cost effective either.
youd need alot of new parts and money, might as well go fi or do some bolt ons
Old Mar 18, 2007 | 02:31 PM
Nic@CiNcity's Avatar
Nic@CiNcity
Just keep what you have and work on that. Makes no sence to trade up for a higher payment to only gain 20 hp.
Old Mar 18, 2007 | 03:42 PM
spiderZ's Avatar
spiderZ
Make sense. Any idea how to make it revolution higher? ... and keep good performance. I'm not thinking about removing the rev limiter but mods like cam shaft ...stroker kit or something like that?
Thx
Old Mar 18, 2007 | 04:17 PM
Nic@CiNcity
Sounds like you need to do a little research. At least you've found the place to start looking around. Good luck to you.
In my own opinion though, i wouldn't waste your money on go fast parts for the Z unless you decide on FI. If it were me staying NA, i'd go with exhaust and maybe one or two other minor things. Then i'd go with suspension and wheels for performance (i don't consider these "go fast parts".) Again, just do some looking around. You'll find everything you need in posts that have already been talked about many times over.
Old Mar 18, 2007 | 04:34 PM
Shift_Z33's Avatar
Shift_Z33
might as well swap in an RB
Old Mar 19, 2007 | 11:46 AM
o snap its eric's Avatar
o snap its eric
you want to look to see what VQHR engine parts can go into our current VQDE engine. Similiar to how some of the B series Honda can benifit from replacing some of their engine parts from other B series engine parts.
Old Mar 19, 2007 | 08:00 PM
rcdash's Avatar
rcdash
you can build up the VQDE for higher revs - new valvetrain ought to do it. Not cheap though... Search for others - a few have built up their motors for 8k rpm
Old Mar 19, 2007 | 08:20 PM
o snap its eric
don't forget that when revving to 8k is considered easy task, the hard task is to make power to 8k otherwise your revving up for nothing.
Old Mar 20, 2007 | 02:58 PM
Ilov350ZEE's Avatar
Ilov350ZEE
do F/I you'll make way more than 306 hp
Old Mar 20, 2007 | 04:00 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Thx
Take car to dealer
Trade in car
Buy 2007
Old Mar 20, 2007 | 05:12 PM
bofa's Avatar
bofa
Why not just spend the $$ on a built motor?
Old Mar 21, 2007 | 11:08 AM
gothchick's Avatar
gothchick
They used to make V8 kits for 280Z's... Maybe you could do something like that... <shruggs>
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
