VQ37VHR goodness
Old Mar 23, 2007 | 09:00 AM
  #41
Resolute's Avatar
Resolute
Originally Posted by THX723
You're getting ahead of yourself there w. the EVTC. The mechanism still works in the same fashion as it's hydraulic cousin. From the outside, it even looks virtually the same. Both are still part of the cam sprocket and driven by a chain. The service manual does show the range of operation to be comparible to the hydraulic variant. Parasidic loss is not an issue in regards to how these VTC work. I'm not certain why Nissan's chose to retrofit the hydraulic unit with the electromagnetic unit on only the exhaust end. It could be for tighter control to better stay withing emission standards.
You're making me work too much on this, LOL! So I went searching for some info on the eVTC. I was sure the timing chain went around the intake cam sprockets only, and it does. But I see now that the exhaust cams have seperate timing chains of their own, connected to their repspective intake cam sprocket, but not directly run by the main timing chain. I guess the DE engine was the same set-up.
Will
Old Mar 31, 2007 | 11:15 PM
  #42
THX723's Avatar
THX723
More details of how the VVEL actuation system works revealed. After studying the diagrams I'm fairly confident I have the actual movement figured out. Whoever came up with this one was definitely thinking out of the box.
Attached Thumbnails VQ37VHR goodness-2070329.003.mini1l.jpg   VQ37VHR goodness-2070329.003.mini2l.jpg   VQ37VHR goodness-2070329.003.mini4l.jpg   VQ37VHR goodness-2070329.003.mini5l.jpg   VQ37VHR goodness-2070329.003.mini3l.jpg
Jambo016
Sep 16, 2016 01:08 PM
