am i limpwristing nuts on the torque bar
Old Mar 23, 2007 | 09:05 PM
andyisphat2004's Avatar
andyisphat2004
Default am i limpwristing nuts on the torque bar
im retarded...im trying to remove the torque bar to get the engine cover off and the nuts wont budge. Am i missing anything.
Old Mar 23, 2007 | 09:10 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
are u using the right size? are you turning it to the right or left?
Old Mar 23, 2007 | 09:16 PM
andyisphat2004
turning counter clockwise and yes using the right size. I always start to second guess things like this, i live in hawaii so all the salt ends up adding to corrosion and making things alot harder to move.
Old Mar 24, 2007 | 04:52 AM
merlin3's Avatar
merlin3
well those are on there pretty tight so you'll probably need a bigger ratchet or breaker bar.
Old Mar 24, 2007 | 05:44 AM
DavesZ#3's Avatar
DavesZ#3
Did you loosen the two nuts to either side of the center bolt?
Old Mar 24, 2007 | 05:58 AM
MUZZY's Avatar
MUZZY
u have to loosen the tensioner bolt... but b4 u do mark ware it is with a sharpi
Old Mar 24, 2007 | 10:24 AM
myZter's Avatar
myZter
PREMIER MEM.FTW
wd40
Old Mar 24, 2007 | 11:08 AM
supra crazy's Avatar
supra crazy
You're weak. push it harder it will come off. or just get a longer wrench.
Old Mar 24, 2007 | 01:41 PM
Shift_Z33's Avatar
Shift_Z33
Just throw a breaker bar on there and it should bust loose. Mine were extremely tight as well.
Old Mar 24, 2007 | 03:36 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the strut bar does not get torqued down that tight at all actually
use some "Nuts Off", let it sit for a little bit and use some muscle - you should not need anything more than a 3/8 wratchet to remove it
Old Mar 24, 2007 | 03:40 PM
Mike Wazowski's Avatar
Mike Wazowski
you need to pump yourself up
hulkout
Apr 28, 2017 09:00 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
samansharif
Sep 25, 2015 12:31 PM
