VQ Oil Analysis and Info
Old Mar 22, 2008 | 10:57 PM
  #441
ZeeForce's Avatar
ZeeForce
Originally Posted by Resolute
I would say most engines break-in faster than 15k miles. In fact, I would not usually expect my own engine to be in the break-in process beyond 2k miles. However, not all engines are the same and some will take longer than others. A UOA is good to show if the engine is still breaking-in or is having difficulty with break-in.
If I was on my other computer, I would find and post that article. I'll put it up later this week.
Will
Perfect, this is the answer I was looking for: “A UOA is good to show if the engine is still breaking-in or is having difficulty with break-in”
Post up the article when you can, thanks again!
Cheers
-Curtis
Old Mar 22, 2008 | 11:33 PM
  #442
Resolute's Avatar
Resolute
*****UPDATE 3.22.08********
Changed some of the Q&A responses to help clarity. I removed the recommended oils, because I don't have the time to keep updating the list as oil chemistries change. I have not updated the UOA comparison charts on the first page. Yet. I'm working on it and will have it done soon, with the new UOA's added along with a running count of the number of samples for each oil tested.
Will
Old Mar 23, 2008 | 05:33 PM
  #443
Puppetmaster's Avatar
Puppetmaster
The lead is most likely from your bearings and the high Fe and Chromium indicate upper cylinder wear. The oil itself is still in grade and there is no indication of fuel dilution for this sample. The biggest factor contributing to wear is the lack of oil in your crankcase. Having only half the volume of oil is a big issue, as the low volume inhibits the oil's capacity for suspension and consistent flow. Upper cylinder wear is only going to make oil consumption worse with blow-by.
Keep a better eye on your oil level in the future, and try another oil. M1 5W-30 has never impressed me, and the high price doesn't give high results. If you like M1, then the 0W-40 seems the best way to go. Otherwise, I would give Valvoline 5W-30 high milage a shot, Rotella T-Syn, or German Castrol 0W-30. Get another UOA with any of these while maintaining decent oil level, and a new UOA done to see how the wear stacks against this sample.
And try a better air filter. Is yours old, or a K&N type? They seem to flow more air, but not filter as well.
Will
Thanks for the feedback, Will. That was my guess too, that it was partly my carelessness and partly the M1 - I'll def be monitoring the oil level better this time (honestly, this was the first time I've burnt this much oil). I've switched to Castrol GTX 5W30 for now, and will shorten the oil change interval to about 3000-3500 miles. I'll post the UOA results when I get them. I do have a K&N filter, haha, unsurprisingly I guess. Thanks again.
Old Mar 23, 2008 | 05:58 PM
  #444
Resolute's Avatar
Resolute
Just jeep an eye on that oil level, and the GTX should be good for a 3500 OCI. Looking forward to the UAO results on that sample.
Will
Old Mar 26, 2008 | 02:50 PM
  #445
Nederlander75's Avatar
Nederlander75
Default Shell Rotella T 5w40 Synthetic (new bottle) VOA
For those interested in newest Rotella T Syn.
File Type: pdf
Old Mar 26, 2008 | 04:32 PM
  #446
QuadCam's Avatar
QuadCam
I thought the newer rotella had a fair amount of moly in it. when did they change the formula? Is it still in the Blue bottles?
Old Mar 26, 2008 | 07:04 PM
  #447
Nederlander75
Still in the blue bottles, but now triple protection versus heavy duty. Bottle is now that funky Sopus top and side handle and smells like gear oil, sulphur.
Old Mar 29, 2008 | 08:04 AM
  #448
Resolute's Avatar
Resolute
Wow, healthy amount of ZDDP in it, and not much else. No Moly, Mg, same levels of Ca. The base stock is good, I'm curious to see the UOA on mine with all the abuse it's taken. I didn't mean to keep running it for a whole year, but it will be interesting to see how it held up.
Will
Old Apr 3, 2008 | 05:20 AM
  #449
merlin3's Avatar
merlin3
resolute, do you have any information about the amsoil 5w40 european car formula? It is recommended for my 300zx as it's turbocharged so I was considering switching to it for my 300zx and 350z since both are twin turbo.
Old Apr 3, 2008 | 07:22 AM
  #450
Resolute's Avatar
Resolute
I haven't seen a UOA on it from a TT engine, nor do I have a recent VOA on the oil. It's pure speculation, but I have heard some people say it's not one of Amsoil's better oils. No facts or reasons, just a bunch of hearsay.
Will
Old Apr 3, 2008 | 07:51 AM
  #451
merlin3's Avatar
merlin3
hmm, decisions decisions. The castrol european oil is now made in the usa so it's not the same correct? I currently have amsoil tso 2000 in my 350 as it's still stock block but twin turbo. I am not sure if there's anything out there that's better but it's time for an oil change. Also my 300zx(vg30dett) is ready for an oil change and currently has mobil 1 5w30 synthetic I think.
Old Apr 3, 2008 | 08:01 AM
  #452
Resolute's Avatar
Resolute
Look on the back of the bottle, since all the Castrol Syntec 0W-30 around here still says "Made in Germany" on the back label. It was gone for a few years, but Auto Zone seems to be bringing it back.
As far as what to use in your TT 350Z, just get a UOA done on whatever oil you like and see how it holds up. It would be easier to work from there, rather than just guessing or going with other people's popular choice.
Will
Old Apr 3, 2008 | 08:05 AM
  #453
merlin3's Avatar
merlin3
ok, well the european formula that i've looked at locally says made in like new jersey or something. I'll see what I can find. I guess I'm not too concerned about my 350 as the engine will be getting built sometime soon.
Old Apr 3, 2008 | 02:38 PM
  #454
Nederlander75
Default Amsoil 5w40 Euro Formula
There is one UOA on this on BITOG from an 05 Alti SE. Did well considering the fuel dilution from the owner's mod causing the ECU to run rich and may have out performed the TSO/SSO had the fuel issue not been there. If you like I will paste in a link.
Old Apr 3, 2008 | 10:06 PM
  #455
Teufel's Avatar
Teufel
I bought 20qt of the German Castrol. It says "Made in Germany" right on the black label.
Old Apr 4, 2008 | 11:56 PM
  #456
djl601's Avatar
djl601
I was researching on the Amsoil TSO oil, but they are discontinued, and has been replaced with SSO 0w-30. Has anyone used that before? Is it the same as TSO?
If i plan to change oil every 3000 miles, would PP 10w-30 be as good as TSO on my 05 non revup w/ 30000 miles? I just got it, and don't even know what kind of oil it's running now, wait to change it this weekend!!
Old Apr 5, 2008 | 07:16 AM
  #457
Nederlander75
The SSO is a little less viscous from what I remember, but has been showing good UOA's on BITOG. Resolute may see it different, but if you are going to such short OCI Id say the PP 10w30 would be a good choice. Even Castrol GTX wouldnt be bad either.
Old Apr 7, 2008 | 05:13 PM
  #458
QuadCam's Avatar
QuadCam
I just got another UOA back from Blackstone. It is another anaylsis using the Rotella T-Synthetic 5W40. For those that don't know, I am running a stock motor revup engine with a greddy TT kit on it. This engine has had a 100 nitrous shot on it for about a year, then a Turbonetics Single turbo for about 6 months, and currently the greddy twins now for over a year (about 20,000 miles of TT use and abuse.)
I find it interesting to see how long the lead from a single tank of race gas is still showing up in the UOA. Also, the Rotella that I am running has no molybdenum in it, so the moly must be residuals from when I ran Motul 300V in the motor.
Anyways, here's the results:
Old Apr 7, 2008 | 05:31 PM
  #459
03aeroZ's Avatar
03aeroZ
Will
i hope they are bringing them back...just in case they aren't, i have enough for the next two changes. stocked up last time i found some. what is the longest time you should leave this oil in an engine or should you even go off time? should mileage be the main factor?
Old Apr 8, 2008 | 08:37 AM
  #460
Resolute's Avatar
Resolute
The Pb will be there for a while. It's not an issue, and it makes reading Pb wear a pain, but aside from the environmental aspects lead is a good lubricant in small doses. In fact, it is sometimes used as a friction modifier in racing oils (such as NEO).
Your engine wear looks really good, especially for a TT engine. Was the T-Syn used last time as well? I am guessing the first sample you have in the UOA is the 300V. The T-Syn really holds up well for TT engines, considering this sample didn't shear out of grade, kept wear metals low, and handles fuel dilution (a problem in FI engines) like a champ. It might be the best "bang for your buck" oil for the FI crowd.
Thanks for posting your results!
Will
