VQ Oil Analysis and Info
This is by far is the only thread that keeps getting better and better with time! Mad props for setting a solid base of information. If only I could add such knowledge in another areas of our cars...lol
Originally Posted by Resolute
The Pb will be there for a while. It's not an issue, and it makes reading Pb wear a pain, but aside from the environmental aspects lead is a good lubricant in small doses. In fact, it is sometimes used as a friction modifier in racing oils (such as NEO).
Your engine wear looks really good, especially for a TT engine. Was the T-Syn used last time as well? I am guessing the first sample you have in the UOA is the 300V. The T-Syn really holds up well for TT engines, considering this sample didn't shear out of grade, kept wear metals low, and handles fuel dilution (a problem in FI engines) like a champ. It might be the best "bang for your buck" oil for the FI crowd.
Thanks for posting your results!
Will
Will
you are correct. the 1st sample in my results are from Motul 300V 5W40. the other 2 analyses are both Rotella T-Syn 5W40. Also, thanks for recommending this oil. You originally recommended it as a cheap oil to put in my motor while I was waiting to get my 300V results back. Once I got the 300V results back, I chose to leave the ROtella in the engine and give it a full 3000+ mile test. When those results came back, I decided to stick with the Rotella. I was planning on trying the Mobil 1 Turbo Diesel Oil, but why? This Rotella T-Syn is turning out to be a great oil. I can't complain about any of the results!!!
Originally Posted by QuadCam
Will,
Will
Could the Moly be from upper cylinder wear, rings? Ive seen this as the case in other engine designs where Moly is part of the Chrome alloy. Guess it could also be assembly lube from your recent mods.
Will
This thread was a great read.
I've used two cycles of motul 8100, but decided to switch to mobil1 0w40 after reading this thread.
Good news was Pepboys had a sale: $29.99 for 5 qrts. of Mobil1 0w40 and a Mobil 1 filter! Sure beats the $50+ for the Motul changes with a OEM filter.
AWESOME THREAD... subscribed
Im having my oil changed later with German Castrol 0w30 & will be doing an oil analysis down the road.
My car is an 04' Enthusiast, 30k miles mostly highway, some city, & some hard driving (a fair mix).
Originally Posted by Scipher21
So what do you guys consider "oil consumption."
Like when its time to change your oil, theres barely any on the stick? or theres half of what you put in it, on the stick?
Will
Hey Resolute, got a couple questions for you.
I'm sure at least one of these has been answered before, but my buddy isn't going to take my research as a final answer.
OK so, from looking at the UOA's, I can see that Castrol 0w30 gives better results than say Mobil1 5w30 (for wear.)
My buddy saw on TV that in Nascar, they qualify the cars using a 0w30, and run them on the track with a 5 or 10w30.
So 2 questions, is a 0w30 good to run all year-round (hot summers), and why do you think they qualify cars in Nascar with a 0w30, and then change to a 5 or 10w30?
Mainly, he wants to know that if it's better to use an oil where the numbers are closer to each other (0w30 vs 10w30) in the summer, even though we see better UOA's from a 0w30.
In any case, yes, you can run a 0W-30 year-round without an issue.
It used to be that straight weight oils were the most stable, because they didn't have any viscosity index improvers in the formula, which are susceptible to shear.
As time went on, ad multi-grade oils became the norm, people realized that oils with low viscosity spreads would use less VII's than oils with higher viscosity spreads. Thus, a 10W-30 was seen as more shear stable than a 5W-30.
Now, chemistry has made these notions obsolete. In fact, a recent SAE technical paper identified several 0W-xx oils as being the most shear stable, over traditional 5W-xx and 10W-xx oils. This is because a 0W-x oil will use higher quality base stocks that don't need any VII's to achieve the grade. German Castrol 0W-30 is a prime example. The PAO base stocks used in this oil have a natural viscosity index to achieve the 0W-30 oil grade all on their own, with very little VII's included in the formula. Mobil1's 0W-xx oils are the same way.
Now, why Nascar would qualify with a 0W-30 and run a 10W-30 in the race, makes no sense to me. Both of those are 30 weight oils and the viscosity will be about the same for both of them. I thought I remembered reading that most of the teams qualified with a 20 weight oil. Of course, with sump sizes measured in gallons, I would think they could run any thing they wanted and be just fine. Those Nascar sumps hold a TON of oil.
Will
Awesome, thanks for the info Resolute
EDIT: I will follow-up and get more info on where he heard that, I know he said he heard it on TV during a race, but I'll get more info.
hey resolute, is there a time frame that one should follow for oil changes (the usual 3mos still apply for synth like the castrol euro?), or should mileage be the only factor? thanks in advance.
Will
