VQ Oil Analysis and Info
Old May 26, 2008 | 07:23 AM
  #501
QuadCam's Avatar
QuadCam
Originally Posted by g35nut
You guys need not to go crazy over all these Blackstone results. Too many variables involved and to few studies to conclusive decide one oil is better than the next. The little advantage on has over the other does not mean the data is statistically significant. Someone one should do a large controlled study...haha.
alot of the debate in the past has come over use of expensive oils, such as the Motul 300V. The MOtul is a fine oil, but it is not proving to be any better (possibly worse)than other oils that cost a 1/3 of the motul
Old May 26, 2008 | 11:15 AM
  #502
06CPV35's Avatar
06CPV35
Agree and that's why this thread of Resolute is so awesome with member supplied data and his interpretations.
It's showing what oils I'll consider or will use and which ones to stay away from. Even certain high cost exotics.
Old May 29, 2008 | 10:10 PM
  #503
mavtais's Avatar
mavtais
OP, is it possible to continue testing on more oil types? I would like to see Mobil 1 0W-30, the stuff in a green tinted jug for more fuel efficiency. The label claims the oil to exceed the protection of 5W- & 10W-30.
Click below to go to the Mobil 1 web page for "green" motor oil.
Originally Posted by Mobil 1
Mobil 1 0W-30 Advanced Fuel Economy is engineered to deliver outstanding engine protection and to offer improved fuel economy in vehicles where SAE 0W-30, 5W-30 or 10W-30 oil is recommended. This low friction, fully synthetic formulation increases engine efficiency and offers outstanding fuel economy. Over the life of your vehicle, Mobil 1 Advanced Fuel Economy can save over $400 in fuel costs.
Old May 30, 2008 | 04:20 AM
  #504
Mike Wazowski's Avatar
Mike Wazowski
all you have to do is use it and send it in for a UOA yourself and post your results. He will then go over the results you have and add the oil to the list he has compiled.
He isnt testing all these oil's WE are.
Old May 30, 2008 | 12:51 PM
  #505
QuadCam's Avatar
QuadCam
+1. be the guinea pig!!! It's probably fine oil. put a good 3000 miles on it and send it off for a UOA. then, post up the results.
I've done it for the Motul 300V 5W40 and the Rotella T-Syn 5W40.
Old May 30, 2008 | 03:20 PM
  #506
Resolute's Avatar
Resolute
I do not test the oils. I do not control which oils are tested.
The oils are tested by independent labs, and the results are posted here. Each forum member shares their own lab results from the oil they used. I have only submitted one UOA, the other 90 plus UOA's are from contributing members.
If you want to see how M1 0W-30 holds up in your engine, use it and do a UOA. Then post it here for everyone else to see, and we'll help you interpret it. After a few more people perform a UOA, maybe we'll see a trend in how it does compared to other oils. That's the point of his thread.
Will
Old Jun 2, 2008 | 12:00 PM
  #507
mavtais's Avatar
mavtais
Thanks. When I have some used 0W-30, I will go through with this. I will also report any mileage gains based on using the oils for the rest of the Z community.
Old Jun 12, 2008 | 07:39 PM
  #508
06CPV35's Avatar
06CPV35
Heard of that oil.
By any chance happen to know which post # you posted your UOA on with this oil? I'm interested in seeing the raw numbers.
Thanks.
Old Jun 13, 2008 | 08:59 PM
  #509
QuadCam's Avatar
QuadCam
Here ya go........
the 1st sample in my UOAs are from Motul 300V 5W40. the other 2 samples are Rotella T-Syn 5W40........as you will see, the lead is high in the last 2 samples from some race gas that I ran.
Old Jun 14, 2008 | 10:13 AM
  #510
Resolute's Avatar
Resolute
I just changed the RTS out of my Z. I had 13 months and 6500 miles on the Rotella T-Syn, and I'll be shipping the sample off for analysis this weekend . I'll post the results and a full write-up when it comes back.
Will
Old Jun 14, 2008 | 10:39 AM
  #511
Mike Wazowski
I just bought this stuff and will be running it to see how it does. Just not in the VQ35. I am going to run it in my Titan.
Old Jun 14, 2008 | 02:07 PM
  #512
06CPV35's Avatar
06CPV35
Here ya go........
Thank you for posting that up. See what you mean about the lead from race fuel.
Will
Interested in those numbers without the high lead from race fuel and your interpretation.
It's this oil correct?
http://www.shell.com/home/Framework?...ellasynth.html
Old Jun 15, 2008 | 01:27 PM
  #513
Resolute's Avatar
Resolute
Originally Posted by 06CPV35
Yep. That's the stuff.
Will
Old Jun 19, 2008 | 06:00 AM
  #514
tquill's Avatar
tquill
Ok well I read the entire thread and I don't believe this was asked... but the next oil I plan on using is amsoil sso 0W-30, and I'll probably do an extending OCI of around 6k-8k... should I change the oil filter during that time period at all?
I should note that I'm using PP 10W-30 now and I'll send a sample of to blackstone for testing... even though I know there are tons of samples for that oil... I guess one more couldn't hurt to average into the chart.
Old Jun 19, 2008 | 09:27 AM
  #515
Resolute's Avatar
Resolute
Any UOA you have to share would be appreciated, thanks!
Use a good filter and it will last for a 8k mile oil change interval. The Donaldson filters that Amsoil labels as their EaO filter will work, but so will Mobil1's filter. Both use synthetic elements and will do fine.
Will
Old Jun 24, 2008 | 05:30 PM
  #516
coachk's Avatar
coachk
Does the Rotella have a good/high HTHS score..I couldn't find it on the site
Old Jun 24, 2008 | 07:08 PM
  #517
Resolute's Avatar
Resolute
Using a viscosity calculator, I figured it to be 4.6
Will
Old Jun 25, 2008 | 01:32 AM
  #518
coachk's Avatar
coachk
What is the scale for HTHS?
Old Jun 25, 2008 | 06:15 AM
  #519
Resolute's Avatar
Resolute
What do you mean, scale? Are you asking what the minimum and maximum values can be, because there is no scale for the oil's viscosity at 150 degrees as defined by grade. It's entirely possible to have a 30 weight and a 40 weight oil with the same HTHS value. GC 0W-30 and M1 0W-40 would be an example, both with HTHS of 3.6 cSt. I've seen the HTHS anywhere from 2.5 to over 5.
Will
Old Jun 25, 2008 | 11:44 AM
  #520
coachk's Avatar
coachk
Yes, I was referring to a minimum-maximum HTHS..In your sticky you said that a higher HTHS score is recommended for FI/Built/Drag
