Need help guys!!! Z wont start....
Old Mar 24, 2007 | 04:39 PM
denic79's Avatar
denic79
Default Need help guys!!! Z wont start....
Well I pulled my car out of storage today. Started right up. I shut it off because I was low on fuel and then a little bit after I tried to start it and it wont start. I pulled the codes and I had a P1564 steering sensor. also fuel level sensor code and some other code. So I cleared all the codes but P1564 wont clear. Im wondering if its the fuseable link on the positive battery terminal is blown. All the dash lights light up but it wont turn over. Or click.
I dont know what to do. I have checked everything else. Does anyone have any ideas. I checked the the link on the batter and it doesnt look like its blown.
Old Mar 25, 2007 | 05:59 AM
denic79's Avatar
denic79
Bump
Old Mar 25, 2007 | 06:28 AM
smallello's Avatar
smallello
I would check other fuses and relays. If you have power for lights etc. but doesn't crank, I think it would have to be a fuse or relay for the starter or ignition.
Old Mar 25, 2007 | 04:46 PM
denic79's Avatar
denic79
Its drivieing me nuts. I worked on it all day today. I checked all the fuses. The fuseable link on the battery is fine. Im wondering if the starter is bad or the keys lost signal with the car. But it should crank at least. It does nothing.
Obadabot
Jun 18, 2023 11:31 PM
Alexreyes
Sep 30, 2015 11:30 PM
