JWT clutch = Exedy Stage 1? / JWT Flywheel = Findanza?
Old Mar 25, 2007 | 12:34 AM
Triple8Sol's Avatar
Triple8Sol
Default JWT clutch = Exedy Stage 1? / JWT Flywheel = Findanza?
Just started searching around, and these seem to be very popular combos.
I've heard that the Exedy Stage 1 clutch kits are just rebranded and sold under the JWT name? Both organic clutch discs.
Also heard that the Fidanza aluminum flywheels are rebranded and sold under the JWT name as well. Both aluminum with steel friction plate.
Any truth to either of these "rumors?"
Old Mar 27, 2007 | 10:43 AM
Triple8Sol's Avatar
Triple8Sol
Nobody has any info on this, either way?
Old Mar 27, 2007 | 12:28 PM
rocks's Avatar
rocks
Even if someone knew they wouldnt tell you, its the way of the 350z community, keep all knowledge a secret.
Old Mar 27, 2007 | 12:32 PM
VicPham's Avatar
VicPham
Lifetime Member
hmm... I would like to know too. If there is a way to save money on a clutch and flywheel combo, then I will go the cheaper route.
Old Mar 27, 2007 | 12:33 PM
Mike Wazowski's Avatar
Mike Wazowski
I know the truth, but Im not telling.
Old Mar 27, 2007 | 12:42 PM
350z_drifter's Avatar
350z_drifter
hahaha no know's in the 350z com
Old Mar 27, 2007 | 01:04 PM
rocks's Avatar
rocks
I do know the JWT clutch disc is an excedy and its the same disc in the wrx sti. The 300zx clutch is supposed to fit the jwt flywheel.
Old Mar 27, 2007 | 09:37 PM
Triple8Sol's Avatar
Triple8Sol
I saw a post where they said the JWT clutch had an exedy logo on it. Just trying to figure out if it's actually the same as the Exedy Stage 1, or if JWT sourced some Exedy parts and have it built to their own individual spec.
Old Mar 28, 2007 | 05:53 AM
rocks's Avatar
rocks
It does have an excedy logo on it. My friend and i compared it to his sti clutch when they were out of the cars they even had the same number on the disc.
Old Mar 28, 2007 | 06:00 AM
VicPham's Avatar
VicPham
Lifetime Member
how much cheaper is it to just buy the Findanza flywheel and exedy clutch stage 1 compared to the jwt clutch and flywheel combo?
Old Mar 28, 2007 | 06:11 AM
Motormouth's Avatar
Motormouth
just saying, Exedy makes clutches for other people, OEM (03 nissan clutch)s and such. I wouldn't be surprised. but I am sure they can custom tailor a spec to a company if they want. I thought GTM was having specialty clutches made, no?
Old Mar 28, 2007 | 11:27 AM
Triple8Sol's Avatar
Triple8Sol
Honestly, I think it's about the same. I'm not asking b/c I want to save a couple bucks. Just need to satisfy my curiosity and know exactly what I'm potentially buying.
Old Mar 28, 2007 | 01:08 PM
350z_drifter
Default clutch and flywheel
i can get the jim wolfe clutch and flywheel combo kit for 725 shipped
the exedy clutch stage 1 and findanza flywheel comb kit kit runs 630 to 700 shipped
but i seen people buying F1 RACING STAGE 1 and findanza flywheel for 660.00 shipped
does anyone know about F1 RACING STAGE 1 clutch
Old Mar 28, 2007 | 01:43 PM
Zivman's Avatar
Zivman
Exedy makes the OEM clutch. JWT clutch is a stock clutch with a modified hub and pressure plate, so it is also a modified exedy clutch. I would assume the JWT and exedy stage 1 are very similar.
The JWT flywheel is made by fidanza. I know this because I used to run a Spec setup. I bought the 'spec' branded lightened flywheel and stage 2+ clutch. It all came nicely packeaged together from Spec. Upon installation, "JWT" is nicely labeled on the flywheel. I ended up chatting with the guys from spec and asked them where their flywheels come from. They replied that if they don't produce them, they are spec'd out from suppliers like Fidanza. So, the Spec, Fidanza, JWT, and probably others like clutchmasters all use the same fidanza produced, JWT labeled flywheel
Old Mar 28, 2007 | 02:46 PM
702Fairlady's Avatar
702Fairlady
And that Spec clutch is quite nice there Ziv, thanks again
Old Mar 28, 2007 | 09:58 PM
Triple8Sol's Avatar
Triple8Sol
So Spec brand flywheels are also Fidanza units, in most applications. Interesting.
Seen the F1 Racing stuff on EBay, but never heard anything about them on the forums.
Old Mar 29, 2007 | 06:38 AM
Zivman's Avatar
Zivman
yes
No problem, glad you got everything sorted out
EnjukuRacing
Sep 30, 2015 06:55 AM
