*PLEASE HELP* Grounding Point Question
Old Mar 30, 2007 | 07:32 PM
rrowen's Avatar
rrowen
Default *PLEASE HELP* Grounding Point Question
Please no flames. I've search for information on this and haven't found it. I just installed a grounding kit on my '06 350z. My question is the (3) wire mounting point on the front of block. There is a thick wire loom going across front of the engine, with a little wire coming out which is bolted to the block. I bolted the 3 wires along with the wire coming out of the loom to the block. Is this correct? Or do I connect the 3 wires by themselves to the block?
Thank-you for your response
Old Apr 1, 2007 | 05:39 PM
03aeroZ's Avatar
03aeroZ
you should have 4 total at that point...the 3 extra and the 1 original
Mattg350z
Oct 2, 2015 06:51 AM
Alexreyes
Sep 30, 2015 11:30 PM
