Power Steering Fluid
Old Apr 11, 2007 | 03:34 PM
BlackSpec02's Avatar
BlackSpec02
Default Power Steering Fluid
When I got an alignment recently the shop told me I was due for a power steering fluid flush. Ive got about 58k on my Z and I bought my Z used at 30k miles. To my knowledge it hasn't been flushed unless it was done at the 30k service.
How do I know if I need a power steer fluid flush? How often should this be done? Is there any particular brand of PS fluid that is better than others?
Thanks for any info/help.
Old Apr 11, 2007 | 03:45 PM
Chebosto's Avatar
Chebosto
relatively easy to drain., open one end of the ps cooler and capture the old fluid. then refill with ATF and then when the car is on, just turn wheel full lock to lock a couple of times and it should be clear of air. its a relatively low pressure system do dont over do it on the hose clamps.
Old Apr 11, 2007 | 03:53 PM
BlackSpec02
oh cool, that sounds like I could do it in my driveway. How much fluid do you need? Also, no need to bleed out the air or anything, just turn the wheel after everything is done?
Old Apr 12, 2007 | 01:23 PM
VIZAGE's Avatar
VIZAGE
You can usually buy by the quart and still have some left over for future. They also sell this synthetic too. Not sure if that plays a big role in power steering oil though.
Old Apr 12, 2007 | 01:37 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
click this thread, and use word find for the word "fluid"
https://my350z.com/forum/2003-2009-nissan-350z/197329-the-top-100-common-questions.html
Old Apr 12, 2007 | 04:02 PM
BlackSpec02
it says genuine nissan psf or in canada use atf? Automatic tranny fluid?
Somewhat confused about atf?
Old Apr 12, 2007 | 05:54 PM
QuadCam's Avatar
QuadCam
I have changed my PSF a few times now. I had to relocate the PS cooling a for TN ST kit, and then I had to relocate it again for the Greddy TT kit.
I am running Mobil 1 Synthetic ATF. It is dexron/mercon rated! 1 quart is all you need, and you''l have about half of bottle left over. You can buy it at Advance Auto Parts; they keep it in stock.
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
Depravity
Oct 1, 2015 04:49 PM
