Im not a Noob, but do I need this part on the car?
Old Apr 23, 2007 | 09:59 AM
zracin's Avatar
zracin
Default Im not a Noob, but do I need this part on the car?
I removed this b/c it rubbed on the exhaust. I havent had it on in a long time, but just got to wondering if i need this? could this have put more strain on my rear transmission mounts? one of the rear oil filled transmission mounts has leaked out oil. probably not related, but curious about this part:
Old Apr 23, 2007 | 10:05 AM
xedes's Avatar
xedes
I don't have it on my car either. I had to remove it to get the exhaust to fit, and so far, I haven't had any problems.
Old Apr 23, 2007 | 10:06 AM
Eazzy's Avatar
Eazzy
That is the Trans mounted Cat Support. If you go with Test Pipes ---No. If you stay with Cats, its best to keep it to relieve stress. It would have no effect on your trans mounts.
Where theres a will , theres a way---shim it, bend it, whatever works.
The Cats are prob over ++ 20 Lbs each, so, keep that in mind
Old Apr 23, 2007 | 10:55 AM
MUZZY's Avatar
MUZZY
dont need it... trash
Old Apr 23, 2007 | 11:03 AM
coreapoc's Avatar
coreapoc
Yah hes right. Except when the remaining brackets get over loaded and over time break while going 70mph on the interstate and then your exhaust bangs the road jamming a broken section into your gas tank exploding the car causing utter death and pain.
Cliffnotes - Nah you dont need it
Old Apr 23, 2007 | 11:14 AM
Eazzy's Avatar
Eazzy
Point is ----- Its a exhaust support bracket that if you have Cats, supports the heaviest part of your system between the headers and the inlets to your muffler. Its your call
Old Apr 23, 2007 | 11:28 AM
HondaKiller's Avatar
HondaKiller
I would put it back on there. Stick a few spacers in between the bolts to help move it away from your exhaust.
Old Apr 23, 2007 | 12:16 PM
mdracer76's Avatar
mdracer76
Cliff notes:
No cats ... no need....
Got cats.. you need.
Old Apr 23, 2007 | 12:21 PM
gothchick's Avatar
gothchick
+1 for the above... But don't trash your oem parts. Always save 'em cause you never know when you may need them and it would suck to have to buy them again when you already had them in the first place.
Old Apr 23, 2007 | 12:32 PM
zracin's Avatar
zracin
no cats. i think im good. so now on an unrelated note-anyone know why the transmission mounts are leaking oil? what would cause this?
Old Apr 23, 2007 | 12:41 PM
Eazzy's Avatar
Eazzy
Unless you have a bolt penitration that is going into the fluid chamber ( you dont, I believe ) you may have a leak elsewhere that is causing it to accumulate at the mount area ( Common )
Keep your rubber mounts clean, the fluid will soften the rubber and cause them to fail
Old Apr 23, 2007 | 01:05 PM
coreapoc's Avatar
coreapoc
and you might want to check your front seal. Might not be visable while parked due to low tranny use but going down the road , the wind will carry it everywhere.
Old Apr 23, 2007 | 06:10 PM
dTor's Avatar
dTor
Kinetix HFCs (the newer version) require you to remove that bracket as it causes the HFCs to crack at the welds. Keep in mind that the HFCs are considerably lighter than the the OEM cats.
Old Apr 23, 2007 | 06:17 PM
jcpeyton's Avatar
jcpeyton
Ditto to dTor. I have Kinetix HFC (really Magnaflo). Installation required removal of the heavy bracket and heavy OEM cats. I'm 5K miles into the install w/ no problems. Save your OEM parts, just in case.
Juztin
Nov 22, 2015 07:03 AM
Mattg350z
Oct 2, 2015 06:51 AM
Ace2347
Sep 22, 2015 03:12 AM
Calinismo350z
Sep 14, 2015 04:04 PM
