Dealer quoted me $250 to install a SS clutch line?
Old Apr 30, 2007 | 09:00 AM
Diesel350's Avatar
Diesel350
Default Dealer quoted me $250 to install a SS clutch line?
Haha So I called to find out how much the dealer would charge to install a SS clutch line and they quoted me $250.00 just for the labor. How crazy is that?
And I already have the clutch line and high temp fluid
Old Apr 30, 2007 | 09:25 AM
Motormouth's Avatar
Motormouth
correct me if I'm wrong, but isn't there alot of labor involved?
Old Apr 30, 2007 | 09:38 AM
Diesel350's Avatar
Diesel350
From what I've read you can do it yourself.
Old Apr 30, 2007 | 09:45 AM
Eazzy's Avatar
Eazzy
Realistically speaking, a 2 hour job for them. Bring in the car, raise on the lift, disconnect, lower, disconnect,route, connect, raise, connect, fill res. Bleed.
85.00 an hour ? 200.00 ? to cover there *** ? Little Hi. DIY
Old Apr 30, 2007 | 09:48 AM
Eazzy's Avatar
Eazzy
The connections can be a PITA. Some use drive pins. Sounds simple and IS, but more to it than meets the eye for a kick *** clean job.
Old Apr 30, 2007 | 12:47 PM
cellude's Avatar
cellude
Is this on a '07 where it doesn't have a triditional slave cylinder? Rather the whole the unit throwout bearing/slave cylinder just sits in the tranny.
Old Apr 30, 2007 | 01:00 PM
infiniteracing's Avatar
infiniteracing
Then do it yourself and send me half the $250 for the advice. See you just saved $125.
Old Apr 30, 2007 | 01:21 PM
Diesel350's Avatar
Diesel350
06
Old Apr 30, 2007 | 01:23 PM
Eazzy's Avatar
Eazzy
If they went to that design ( Others have ) then as a rule the bleeder and the line connection are still on the exterior of the trans.
They are a PITA to bleed out
Old Apr 30, 2007 | 01:47 PM
Z CRUZN's Avatar
Z CRUZN
Took me maybe 30 minutes to replace the line with the Z on a lift, but about 1 1/2 hrs. to bleed the darn thing with new hi-temp fluid - lots & lots & lots of pedal pumping to get it fully operational... Well worth it after boiling the OEM fluid twice in a weekend at the Tail of the Dragon a couple years ago.
$250 sounds like a little too steep, but then again, it IS a dealership....
Old Apr 30, 2007 | 04:55 PM
jonnylaw's Avatar
jonnylaw
IT a pita to install, but I only got charged for one hour of labor at the dealer ($100).
Old Apr 30, 2007 | 05:23 PM
Alberto's Avatar
Alberto
Cranky FI Owner
It not a PITA! It takes all of 1 hour (TOPS) with the help of a friend to bleed the system when your done.
Old Apr 30, 2007 | 05:25 PM
jonnylaw's Avatar
jonnylaw
I meant pita if you are only one person doing the swap and bleed. You're right w/ the help of another it should take under an hour.
Old Apr 30, 2007 | 05:38 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
way too expensive....I think they just don't want to do it.
1.0-1.5 hour labor TOPS including bleeding the clutch.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
