Crank Pulley Question
Old May 5, 2007 | 06:56 AM
filmnews's Avatar
filmnews
Default Crank Pulley Question
Why do a lot of people on this board say not to use a light crank pulley if you plan on going turbo or supercharged? I know a lot of people who use light weight crank pulley's with their boosted setup.
Old May 5, 2007 | 08:27 AM
Ztalker's Avatar
Ztalker
just don't use the underdrive pulley for turbo.
Old May 5, 2007 | 08:40 AM
filmnews's Avatar
filmnews
Is it ok with the Vortech SC?
Old May 5, 2007 | 08:47 AM
Ztalker's Avatar
Ztalker
i don't think so, not recommended by the manufacturer.
Old May 5, 2007 | 01:01 PM
sentry65's Avatar
sentry65
the burninator
don't underdrive with the vortech. Lightweight is fine as long as it's the same diameter. Underdrive pulleys will lose power from the vortech and make less boost
Old May 5, 2007 | 01:09 PM
If you are installing forced-induction, why mess with inconsequential bolt-ons like a crank pulley?
Old May 5, 2007 | 03:25 PM
sentry65's Avatar
sentry65
the burninator
every bit helps, the faster you can rev up, the faster you accellerate
Old May 5, 2007 | 03:28 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
i could see using one for a turbo, since its exhaust driven. But, for vortech no. You dont want to underdrive the vortech.
could you then get a smaller pulley for the vortech, one that is 85% smaller would match the UR size. Then youd probably need a new belt. @3.33 stock, 85 is 2.83, does that seem right?
bad part is, ill find out eventually. Im going vortech, but couldnt seem to get my ur crank pulley off when i went to sell it. Gonna have a shop look at it.
Old May 7, 2007 | 12:57 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
its fine for a turbo car
no reason you could not use the stock diameter lightweight crank pulley on the Vortech equipped car though
Fixxxercask
Nov 9, 2015 11:10 AM
