royal purple...power loss
Old May 16, 2007 | 04:22 PM
0350z33's Avatar
0350z33
Default royal purple...power loss
Hey, I also posted this on my350z and am trying to get some good responses because im stumped on this. This weekend i changed my oil to royal purple 5w-30 and ever since then i have seen some power loss. i have also been smelling what seems to smell like a burning oil smell from the car, sometimes it faint.. after a quick fly through some gears it is a more pronounced smell. i also changed the oil filter and changed the crush washer. Has anybody experenced something like this before when they have changed there oil or do you think i have got a bigger problem then i might expect. there were only 5 quarts of oil put in and by the dipstick it seems to read between low and high... 2000rpms is 60psi.. any ideas would be greatly appreciated! thank you.
Old May 16, 2007 | 04:32 PM
___DJK___'s Avatar
___DJK___
Old May 16, 2007 | 04:34 PM
davids's Avatar
davids
F U StuLax18
Did you see this in your exhaust fumes or on an actual measurement, such as a dynometer?
More than likely, it's just in your head.
Old May 16, 2007 | 04:51 PM
Welcome to the forum. Changing motor oil, any motor oil, does not cause the symptoms that you described. Impossible.
Old May 16, 2007 | 05:35 PM
0350z33's Avatar
0350z33
i didnt think so either but it happened literally right after i changed the oil.. and the burning oil smell still continues 5 days later. my friend changed his oil the same day to royal purple and have any burning oil smell or problems(wrx). the car feels like the ac is running now all the time or i have an extra person in it all the time and its a noticable loss.
Old May 16, 2007 | 05:43 PM
ZCARBANDIT's Avatar
ZCARBANDIT
go to http://www.bobistheoilguy.com/ and check out what people say that may have tested it.
Old May 16, 2007 | 05:44 PM
Mazinger Z's Avatar
Mazinger Z
+1. You DID put 5 quarts of oil in right???
Old May 16, 2007 | 05:47 PM
0350z33's Avatar
0350z33
yep i put in 5 full quarts and changed the filter... no clue whats up with it
Old May 16, 2007 | 07:29 PM
LG_z33's Avatar
LG_z33
All in your head. The car probably feels much smoother, therefore giving the illusion of less low end torque. For the record I use rp 10w-30 in my revup with great results.
Old May 16, 2007 | 07:31 PM
0350z33's Avatar
0350z33
thats sounds possible accually... but what about the smell?? should i be worried?
Old May 16, 2007 | 07:37 PM
flintgauge's Avatar
flintgauge
it's all in your head. I have been running RP from day one, it is alot smoother and I noticed that on my other cars when i changed over, it's a bit quieter too, giving the subtle illusion of a loss of power. Or that you're going deaf... You're fine man. As far as the smell, you may have dripped some oil accidently onto your manifold or headers and now it's burning off.
Old May 16, 2007 | 08:01 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
post some dynos of the power loss or
Old May 16, 2007 | 08:03 PM
LG_z33's Avatar
LG_z33
careful, he's going to post a picture of his butt :P
Old May 16, 2007 | 08:08 PM
Blk03G35's Avatar
Blk03G35
It's all in your head
Old May 16, 2007 | 08:13 PM
black06z's Avatar
black06z
I agree that its all in the head. Never heard of a power loss from an oil change and quite the opposite with RP, which is suppose to gain some.
Old May 16, 2007 | 08:15 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Burning oil smell can come from a small amount of oil that spilled on the motor or any place that is hot, such as the exhaust.
Old May 16, 2007 | 11:30 PM
ZTMYDUST's Avatar
ZTMYDUST
Switched over to RP 5w30 two days ago, Def didn't notice anything like this and the car feels so much smoother like the motor is taking a breather all the time (which i quickly put it back in the game with my right foot to the floor making those 6 pistons play the tune i want!)
Soon switching to RP brake, Clutch, everything!
Old May 17, 2007 | 05:47 AM
clipso 01's Avatar
clipso 01
drive for a fw hundred more miles and then check your oil level
Old May 17, 2007 | 05:57 AM
rednezz's Avatar
rednezz
I have been RP for a couple of years in my Z and never had any problems that you mentioned. However, if you race your Z and run RP and would be cautious. My motor was completely NA and it spun a bearing killing my motor with only 60,000 miles. I always changed my oil at 2,000 mile intervals with RP 10-40. Now I am not saying RP killed my motor because I did have two years worth of doing road racing and high speed track events so that was the major factor. I do think RP didn't protect my engine as well as say AMSOIL racing oil because other engines with more racing miles on it that ran AMSOIL had alot less wear. I believe RP does add HP but sacrifices some protection in extreme conditions. If you do road race your Z and run RP be cautious...check you bearings if you can.
Old May 17, 2007 | 08:58 AM
0350z33's Avatar
0350z33
hey, i got in and drove the car this morning and it has all of its power... but it still does smell and i did see some whitish smoke this moring after a 30 min ride with the oil smell.. i check the oil filter and it is tight.
