Project Car Stage 2 - MREV2 & 5/16 inch spacer
Old May 17, 2007 | 05:51 PM
dlmann1217's Avatar
dlmann1217
Default Project Car Stage 2 - MREV2 & 5/16 inch spacer
We've just completed step 2 in our Project G35 Coupe. Installed a Motordyne MREV2 and 5/16" spacer and ran it on the dyno for a baseline and with UTEC tuning. The results speak for themselves: http://www.envisionelite.com/content...=1&pageid=4585
Vehicle has CAI, MREV2, and Spacer at this point. Exhaust modifications will be starting soon so stay tuned for more articles.
Dave
Old May 17, 2007 | 05:56 PM
Armitage's Avatar
Armitage
I did the spacer and once the ECU adjusted, it seemed to pull harder mid-range and up top. Very nice gain.
Should've done the MREV2 at the same time, but oh well.
Edit - Looking at your results, not sure I want to do the MREV 2 now. 11whp is a lot of loss in the last 1k RPM's.
Old May 17, 2007 | 07:23 PM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Can you try dyno'in your car with your cai changed to ram? From my understanding it affects performance a bit, but thats from what i read..
Old May 17, 2007 | 09:10 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Give it a dyno without the long tube CAI (just use the stock box). It will make better results.
Old May 18, 2007 | 02:34 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Unless I'm missing something, your tuned AFR looks like it's all over the place. Get that UTEC tuned a little better and your power band will be a lot smoother.
And was there a before and after of the CAI somewhere on there? I couldn't tell... in any case, I'm with Tony for taking it off
Old May 18, 2007 | 05:41 AM
gothchick's Avatar
gothchick
Yeah... That is one mess of an AFR curve.... For a NA G/Z, it should generally start in the 14-15 range (around idle) then gradually richen up to 12-13 (towards redline) in a nice smooth curve...
Old May 18, 2007 | 10:13 AM
dlmann1217's Avatar
dlmann1217
That was oddly enough the AFR setup that seem to yeild the best results. When we did the last dyno comparison with the Injen vs the Fujita short ram we saw no gains at all with the short ram. When we do the exhaust article I will try swapping intakes back and forth again to see what yeilds the best overall results.
Dave
Old May 18, 2007 | 02:02 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Dave
That is kind of wack. I question your air/fuel sniffer's accuracy.
If that AFR curve really gave the best results then you probably have some weird timing **** going on.
RiujinZero
Apr 16, 2021 11:31 AM
JjL
East Canada
Jun 12, 2019 03:04 AM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
torchkc
Sep 11, 2015 08:26 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
