just got done changing diff oil
Old May 20, 2007 | 12:20 PM
DJMatrix1067's Avatar
DJMatrix1067
Default just got done changing diff oil
Just got done changing my diff oil. My car is at 25,000 miles ish and i read somewhere that a diff oil change can be good for the car.
So ya, for all of you that have never done this, best 30 mins of my life. The car rolls sooo much easier now, so less revving when clutching out from a stop. It rolls easier on hills and stuff too. Generally speaking, just the acceleration feels a lot smoother. I'm glad I did it. I'm pretty sure it was a premature change (it didnt need to be changed yet) but there was SO much nasty crap that came out of there.
If you have never done it, i recommend it.
Old May 20, 2007 | 12:21 PM
diwun67's Avatar
diwun67
What kind of oil did you use?
Old May 20, 2007 | 12:25 PM
DJMatrix1067
i used Castrol Syntec Full Synthetic 75W-90.
I'm going to use Redline oil in my trans when i do it next weekend, but i had to special order GL4 instead of GL5.
For those who dont know, GL5 in the transmission will damage the synchros... FYI
Old May 20, 2007 | 12:29 PM
ZCARBANDIT's Avatar
ZCARBANDIT
speaking of synchros we have the same as the 6 speed frontier. isnt that something.i know 2nd is the same and think all the others are as well.
Old May 20, 2007 | 07:55 PM
ROSELL0522's Avatar
ROSELL0522
Stick to amsoil for all fluids. It might show at their site but sign up to get info to buy wholesale and it shows(from an outside test not amsoils) in the brochures that they have the best viscosity on all fluids(doesn't break down as fast as other fluids). Plus they have a XL version that just the filter needs to be changed after 7500 to continue until 15000 before filter and fluid need to be changed to save money on oil changes. I do mine at 6000(filter)-12000(both) and have seen a difference in the fluid(stock though not FI).
Old May 20, 2007 | 11:23 PM
DJMatrix1067
thanks. ill keep that in mind. i try and change my oil every 4,000 miles just to be safe. its a little cost here, that saves a LOT of cost later.
Old May 20, 2007 | 11:56 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Exactly my assessment right after I changed it....
it's time and money well spent.
Old Jun 14, 2007 | 02:30 PM
VQ40's Avatar
VQ40
Question What?
You guys can actually feel a difference in performance just from changing the differential oil?
Old Jun 16, 2007 | 07:38 AM
rcdash's Avatar
rcdash
I measured a signficant performance boost on my Gtech-RR doing immediate before/after. It not only felt smoother, but the car was faster.
The rear diff is a significant component of drivetrain loss. When I changed at 18k miles, metal shavings and stuff that looked like poop came out at first, then eventually some clearer fluid. yuck. change it - you won't regret it.
I think I used royal purple... you should replace the crush washer - the part number is listed on a thread here or on g35driver.
Old Jun 16, 2007 | 08:08 AM
ZCARBANDIT's Avatar
ZCARBANDIT
when i did my diff it was for the heat issue mainly.i am using rp now but will be trying motul next.you'd be surprised how much heat you lose by adding synthetic.and along with a aluminum finned diff cover, that would be even nicer.
Old Jun 16, 2007 | 02:13 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Here's how it all went down for me:
New car -> felt great to launch and drive
7k miles-ish -> clutch started to feel weak, like it wasn't grabbing hard enough. Had to rev to higher RPMs to launch
10k miles -> problem got even worse. I considered buying a new grabbier clutch, but before I did that, I changed trans and diff fluid. the diff fluid was all black and full of metal shavings. After changing the fluid, car would roll without assistance on VERY slight inclines that it would not previously roll on. Lower RPM can be used for launching now, clutch "feels" stronger.
18k miles -> problem is back... I am going to change out the diff fluid (only) again. I assume that the diff was not done breaking in. Hopefully this time the fluid will last longer. Scratch that... I don't think the fluid is at fault, it's just that the diff is still breaking in...
Changing the Diff fluid made a huge difference in feel. The transmission fluid felt pretty similar before and after. But, the transmission now works like BUTTER when it's warmed up. So I sacrificed some cold shifting performance for excellent warm shifting characteristics.
Old Jun 16, 2007 | 02:27 PM
Rick06Z's Avatar
Rick06Z
Old Jun 16, 2007 | 02:28 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by Rick06Z
My rear diff oil was changed at 5K (km's) and even with that low of mileage the oil was blackish and had shavings in it. When I saw that, I changed the MT oil at that time as well.
Just did RP in engine, MT and rear diff a couple days ago (now at 17K kms). Local lube shop charged me $50 to change all 3 as I supplied the fluids and filter. I know it is probably overkill to change MT and diff fluids again at only 17K, but I think changing once a year is a low cost to know its all good.
I think synthetic trans fluid should be good for 60k-100k easy.
Old Jun 16, 2007 | 02:30 PM
SuperBlack350z's Avatar
SuperBlack350z
sure does. I had to special order too. the guy kept saying that 350z are newer cars and that they take gl5
Old Oct 28, 2008 | 12:30 PM
tquill's Avatar
tquill
Nevermind I found it
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
