Flywheel? Should I?
Old May 31, 2007 | 12:04 PM
oman's Avatar
oman
Default Flywheel? Should I?
I've been doing some resarch on lighter flywheels and am trying to decide what brand to go with? Nismo, Exedy, or ACT? Whats the pros and cons on lightened flywheels? Is it worth the money? Will the rpms jump higher/quicker response? Do you have one if so was it worth it?
Old May 31, 2007 | 12:14 PM
Kolia's Avatar
Kolia
It will make a big difference to the way the engine responds to throttle input. Faster rev up AND down.
I had one on my Suby. it was fun, but drivability suffered a good deal. Forget driving in a relaxed manner. Frankly, the way my engine revs (I have a rev-up 300hp), I don't see a lighter flywheel to be worth the daily hassle. The VQ35 still revs faster than my lightened ej25 from the Suby.
Use the money somewhere else instead.
My 2 cents...
Old May 31, 2007 | 12:58 PM
Ztalker's Avatar
Ztalker
^+1
Old May 31, 2007 | 01:14 PM
97supratt's Avatar
97supratt
I loved my ACT clutch/flywheel combo but it isn't worth it if your clutch isn't bad.
A flywheel will definitely make the Z a lot more fun and easier to drive in racing applications but it takes a little getting used to on the street.
If you are going to replace your clutch, then do it. If not, save your money for other parts.
Old May 31, 2007 | 01:16 PM
Crom's Avatar
Crom
I got a new unorthodox for dirt cheap.....
Old May 31, 2007 | 01:19 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
yeah i was wonderin about this too, i am about to go procharger and thinkin of flywheel/clutch.. not sure if i need new clutch but im guessin i will. But flywheel was somethin i was looking around for and would pick one up if it is worth it.
Old May 31, 2007 | 01:29 PM
doskiez's Avatar
doskiez
I love my Fidanza its 13.5 lbs and i couldnt be happier (non rev up). It was a little bit harder to drive at first, but i got used to it fast.
Old May 31, 2007 | 01:36 PM
Get_Zwole's Avatar
Get_Zwole
why is it harder to drive?
Old May 31, 2007 | 01:49 PM
See: What flywheel do I need?
http://www.ramclutches.com/Products/flywheels.htm
Old May 31, 2007 | 03:33 PM
RebelinRI's Avatar
RebelinRI
If you're going to open it up then do the flywheel for sure. Daily driving isn't that bad. For me.......... I would do it.
Old May 31, 2007 | 05:35 PM
eltness350's Avatar
eltness350
The Untouchable
do it....rev faster...driveablility...ehhh fu*k that its go time....
Old May 31, 2007 | 07:03 PM
jonnylaw's Avatar
jonnylaw
B/c often you must adjust to a new engangement point, a lessened amount of play, but imo the benefits outweigh--and some setups might even actually involve less pedal effort, if multiple clutch disks are used.
Dr.Paulyy
Jul 29, 2019 07:45 AM
RyansZ33
Sep 15, 2015 05:54 AM
