High idle at startup, whoa!
Old Jun 6, 2007 | 12:23 PM
Z-T's Avatar
Z-T
Default High idle at startup, whoa!
New '07 with 660 miles.
Does anyone else experience excessively high rpm's during engine startup (from cold)?
My idle for the first 1-2 minutes is above 2100rpm. Also, the initial start throws the needle past 2300, 2400 rpm. After the first minute or so it comes back down fairly quickly, but initially it seems too high. Almost all my other cars do this, but none to this extent.
Is this normal for the Z?
Old Jun 6, 2007 | 12:53 PM
Agathron's Avatar
Agathron
I've got an '07 with about 350 miles on it (dam that break in period) and have noticed the same thing. It does almost exactly what you're describing. I noticed that when you push the clutch in and let it out it also drops about 75rpm almost immediately. I generally let it drop down all the way before starting to drive.
I hope this is normal, don't want to have to go back to the dealership, they were less than splendid.
John Bronze's Avatar
John Bronze
its normal
Old Jun 6, 2007 | 01:14 PM
Bumpinjeep's Avatar
Bumpinjeep
Mine does the same
Old Jun 6, 2007 | 01:15 PM
SniperHunter's Avatar
SniperHunter
You should see how a Lexus starts up - goes to 3k until it settles down at 1k.
Old Jun 6, 2007 | 01:16 PM
97supratt's Avatar
97supratt
It's perfectly normal. The idle control does that to warm up the motor for a bit then lower the idle. You can sleep better at nights now. lol
Old Jun 6, 2007 | 01:30 PM
Z-T's Avatar
Z-T
Lol.
True. My Tacoma, WRX and A3 all do the same thing, but the Z wins for highest rpm
Old Jun 6, 2007 | 01:33 PM
SargentZ's Avatar
SargentZ
Mine does the same thing. AC will kick it up too. It dies down relatively quickly so it never freaked me out, now the oil pressure increase after my first oil changed did, but I'm told not to worry.
Old Jun 6, 2007 | 01:36 PM
MadNismo's Avatar
MadNismo
its like having a choke the ***** is cold so the rpms go up.....
Old Jun 7, 2007 | 05:37 AM
blackstealthz's Avatar
blackstealthz
Kinda freaked me out too at first but yea its normal.
Old Jun 7, 2007 | 05:38 AM
Smawg350's Avatar
Smawg350
its the motor warming up, you are fine.
Old Jun 7, 2007 | 08:12 AM
97supratt's Avatar
97supratt
Originally Posted by Z-T
Lol.
LMAO
Imagine they had a contest like that. The winner would have to be a McLaren F1 GTR cuz it would sound the sweetest.
Old Jun 7, 2007 | 12:00 PM
Changvi's Avatar
Changvi
Mine goes to 1500-1800rpm for 1 minute or 2m then diips down.
Old Jun 7, 2007 | 01:19 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Your motor is going to blow up for sure
Old Jun 8, 2007 | 04:57 PM
ML2000's Avatar
ML2000
My 06 does the same thing.
lapham3
Oct 7, 2022 03:15 PM
liqalu04
Jan 2, 2022 12:58 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
