problem with 07
Old Jun 10, 2007 | 09:33 AM
cltype-s's Avatar
cltype-s
Default problem with 07
i was driving home from work last night and i had just started driving my car, it was still cold so i didn't let it warm enough i guess, because when i flored it in first and i missed second and over reved it, it hit the rev limiter and i herd my exhaust pop really fast. well after i did this i tryed taking it easy and then started trying to excelerate hard in first but the car had absolutely no power in low rpm's i would try floring it and it was like it had no power at all, i was on low fuel maybe 35 miles left but no engine lights came on any idea on what happened. by the way after i turned off the car and let it sit for a while i took it for a drive and it felt normal again and started taking off fine
Old Jun 11, 2007 | 03:34 AM
Riley07's Avatar
Riley07
It sounds like a mechanical over rev...Take it to the dealer and let them check it out ASAP
Old Jun 11, 2007 | 03:42 AM
ekim1's Avatar
ekim1
uuuhhh-oohhh...you broke it
Old Jun 11, 2007 | 07:17 AM
shocka04's Avatar
shocka04
how did you miss 2nd
Old Jun 11, 2007 | 08:29 AM
doublins's Avatar
doublins
He could not have had a mechanical overrev if he started in first gear then missed 2nd- at the most, he simply floored it off of the rev limiter- a mechanical overrev is when you are travelling too fast for a given gear, then downshift, causing the wheelspeed to force the engine to spin higher than the rev limiter.
How has the car been driving today?
-C
Old Jun 11, 2007 | 08:31 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
It probably went into "limp mode" and if it felt normal after the restart, you should be 100% fine
Old Jun 11, 2007 | 08:34 AM
Richy350Z's Avatar
Richy350Z
i'm surprised he didn't miss first.
take it slow bro!
1. New Engine
2. Cold Temperature
3. Red Line
= F*cking up Motor
Let it break in!
Old Jun 12, 2007 | 04:55 AM
6894kevin's Avatar
6894kevin
Problem isn't the 07Z it's the driver
Missed 2nd
35 miles left in the tank Never let it get below 1/4
Over rev "well after i did this i tryed taking it easy and then started trying to excelerate hard in first "
WHY take it easy then thrash on it by excelerating hard in FIRST!!
I am sure you didn't hurt anything too bad, but have you done the break-in?
When you stoped for gas and let it sit it, did it go back to normal when you started her back up? It's fine just be easy it's a new car!
Old Jun 12, 2007 | 08:17 AM
97supratt's Avatar
97supratt
Preach! Preach!
Old Jun 12, 2007 | 09:01 AM
cltype-s's Avatar
cltype-s
yah it's perfectly fine now
Old Jun 12, 2007 | 09:09 AM
97supratt's Avatar
97supratt
Good to hear.
Old Jun 12, 2007 | 09:58 AM
sibble's Avatar
sibble
good topic for a new thread cuz i dissagree
that's something my grandfather always told me when i was younger, and i heard people say its good practice to do...
i dunno me and my friend were talking about it a while ago, and he tends to over-think scenarios when he smokes his blunts, but he made a point
what if theres some stuff sitting at the bottom of the tank that never gets out? and one day you happen to not quite make it to that gas station and go below 1/4th...
but then again, if it's in the tank its, its in the tank, and its gona get out one way or another...
Old Jun 12, 2007 | 10:15 AM
nkohler's Avatar
nkohler
easier on your fuel pump to not run it dry. If there is crap in your tank you have more problems than running out of gas.
Old Jun 12, 2007 | 01:20 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Just FYI even when your distance to empty reads " -- " you still usually have 3-4 gallons left
Old Jun 12, 2007 | 01:25 PM
Blue_Z's Avatar
Blue_Z
take it slow bro!
1. New Engine
2. Cold Temperature
3. Red Line
= F*cking up Motor
Let it break in!
lol, this reminds me of a time everyone was coming out of a club because last call was over. it was like 40 degrees outside, and these ricers got in their civic (which still had condensation and dew from sitting out so long), started the car and a split second later redlined the engine in neutral a few times to get everyone's attention. it was probably the stupidest thing I ever saw.
Old Jun 12, 2007 | 01:26 PM
6894kevin's Avatar
6894kevin
I said that to save the fuel pump, it's common sence that the pump should stay submerged. As for anything in the tank your right, and something to think about is the fact that you stir up stuff in the tank everytime you drive (stop/go) and when you fill up.
Cheers
Kevin
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
