My First Baseline Dyno
Old Jun 12, 2007 | 05:15 PM
Das350z's Avatar
Das350z
Default My First Baseline Dyno
I have a 2004 350z, it was done with my aftermarket wheels and there was some trouble getting my tires not to spin while on the dyno. From what I have done to the car, which is listed in my signature is a bit disappointing. I wish if I did a stock baseline dyno but didn't think of it at the time.
Please let me know how this dyno looks to you.
Thanks, Dan
Old Jun 12, 2007 | 06:00 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
There is definately some serious power and trq left on the table. With a retune of that AF curve, at least 10-15whp easily. We usually see peak power/trq on NA applications in the low to mid 12's AF.
You have some good mods...now you just need a tune.
Old Jun 12, 2007 | 07:27 PM
Das350z's Avatar
Das350z
Nice that makes me feel better. That is what I was going to do next to finalize my N/A mods for a while before I go F/I. I am just deciding between the Technosquare reflash or a Utech tune. I am leaning towards the reflash though although I know I wont be able to squeeze out as much power the cost and convenience is better. Thanks for the reply Sharif
Old Jun 12, 2007 | 09:22 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
owning a dynojet , i just have to say, there is NO way you were spinning the tires on the dyno unless they just didnt have your car strapped down right. your numbers are on par for what bolt on dynojet numbers usually make...
Old Jun 12, 2007 | 09:56 PM
Das350z's Avatar
Das350z
Lol, I have no idea but thats what the dyno operator told me when i kept getting readings of around 170 hp to the wheels. He had to reposition my rear wheels on the dyno after and told me it had to do with the independent suspension. Thanks for the reply Jeremy, im feeling much better that they are pretty much normal for a non-revup motor.
Old Jun 12, 2007 | 10:00 PM
Audible Mayhem
My350z
he is dumb, also, if he did a couple runs with 170 the wheels, he probably really hurt your readings. usually on my dyno the second run makes the most power and any runs after that keep losing and losing...
i do many many many independent rear suspension cars on my dyno, i thnk he might not know how to strap the car down for accurate readings...
Old Jun 12, 2007 | 10:06 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I don't really understand why you posted a sad face.
Either get tuned, go F/I, or accept what you pulled...
Old Jun 12, 2007 | 10:08 PM
skaterbasist's Avatar
skaterbasist
Numbers are just numbers. Nothing more to it.
Come to think of it, this dyno is pretty much useless without a stock baseline, or atleast a dyno with fewer mods.
Old Jun 13, 2007 | 09:31 AM
Das350z's Avatar
Das350z
Yeah true, I was just expecting higher because most of the dynos ive seen have the same numbers w/o headers. Now im happy because I am getting a reflash and within a year the new Powerlab single turbo kit. So like skaterbasist said number are just numbers.
Thanks for the replies
Old Jun 13, 2007 | 09:46 AM
Das350z's Avatar
Das350z
I took out the sad face Wired
Old Jun 13, 2007 | 10:45 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
don't worry, be happy
Old Jun 13, 2007 | 03:26 PM
pmohr's Avatar
pmohr
Why is it plotted vs MPH and not RPM?
Old Jun 13, 2007 | 05:35 PM
Sharif@Forged
Forged Performance
Probably couldnt find a good tach signal, or didnt want to hook it up.
Old Jun 14, 2007 | 12:44 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I love my UTEC! I'll be honest, it didn't get me the peak power I would like to brag about. I did get an average of 10whp/wtq in the midrange.
Old Jun 14, 2007 | 11:24 PM
gsazabi's Avatar
gsazabi
UTEC all the way! With it I gained 10whp with Nismo exhaust setup, and 15whp with my new HKS Ti exhaust setup.
Also, my peak torque comes in at 3500RPM instead of stocker's 4800RPM.
It makes power delivery quite a bit more linear than it already is, but I do get that flat torque curve
Old Jun 17, 2007 | 09:29 PM
Das350z's Avatar
Das350z
Ok, thanks for all the replies, now I just have to make my final decision on a tune or reflash. I was really leaning towards the reflash but now its pretty much balanced out between the two. Life's tough decisions
Old Jun 17, 2007 | 09:53 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Here is a reason I don't like reflashes 1) Its a guess of what your engine is doing. Someone sayd "This is what my car did so your's should be doing the same with simular mods." 2) The next performace mod you do you need to spend the same amount of money for another reflash.
Invest in the UTEC!!! It will benefit you in the long haul. Plus they are going for $700-$800 new these days! I bought mine when they were $1k.
EDIT: Just saw you're sig say "Turbo Soon." Don't waste your money on a flash get the UTEC. You'll need it when you go boost.
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
