My Z is sick...
Old Jun 17, 2007 | 11:28 PM
FlyingSquirrel's Avatar
FlyingSquirrel
Default My Z is sick...
Got an 06 Track.
Symptoms:
Rev limit of 2000 RPM
Service Engine Soon Light/VDC/TCS on (Steady)
Sputtering
Idling at 2,200 (up and down)
Mods:
Nismo CAI
Heavy Foot
What do i think the problem is?
Either i have some bad gas in my tank, or my MAF is dirty.
I filled up the day before with shell optimax. I washed the Z today at 1200.l Went for a fun little drive and ended up getting the cut out at 6,000 rpm. Stopped and put in some (italian product to take the water out of the gas tank) at the gas station.
I'm thinking i should just drain it.
Q#1
What do you use to clean your MAF?
Q#2
Is there a drain bolt on the Z's gas tank?
Thanks in advance.
Old Jun 17, 2007 | 11:32 PM
9kFever's Avatar
9kFever
no way you sucked water in your intake? Dont know the specifics on the Nismo CAI
Old Jun 18, 2007 | 12:02 AM
ASTIG_Z's Avatar
ASTIG_Z
i am also thinking hydrolock.
Old Jun 18, 2007 | 12:23 AM
FlyingSquirrel
I bucket washed the car with two 3 gallon buckets of water, i think it's pretty unlikely - But i suppose it's possible.
If you were me, what would you do?
Old Jun 18, 2007 | 05:43 AM
HondaKiller's Avatar
HondaKiller
If i were you, i would drain the tank and refill. Check the MAF for build up or moisture. It's hard to diagnose, but it would take a lot of water to make it up a Nismo CAI. I've sprade my filter on my CAI with the pressure washer through the grill while washing the car with no affect. Hydrolock sounds unlikely unless you've been driving through puddles/small lakes
Probably bad gas partner, or lets hope so.
Old Jun 18, 2007 | 05:46 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Take the car and have the codes scanned-report back.
Old Jun 18, 2007 | 05:48 AM
THE TECH's Avatar
THE TECH
I don't believe that it is the MAF or air filter. Find out what codes you're getting and go from there.
Old Jun 18, 2007 | 06:11 AM
jtabraham's Avatar
jtabraham
If Cleaning the MAF sensor will give you peace of mind, it's quite simple to do. Remove the harness, unscrew the two small screws holding it to the intake tube. When cleaning take car to only hold it by the plastic housing, and do not touch the plates or any of the wires.
Buy a specific MAF CLEANER (CRC makes a good MAF cleaner, although I'm not sure if it's available in Europe), or mild electronic parts cleaner. Spray short bursts on the inside and out of the sensor, taking care not to make any contact with the wires between the plates. Let the solvent air dry off of the sensor before reinstalling.
As others have said however, I don't believe the problem is your MAF.
Old Jun 18, 2007 | 06:25 AM
Lawy'dU's Avatar
Lawy'dU
It's not hydrolock. If his car was suffering from hydrolock it would not run at all. Plus the nismo cai has a bypass valve to avoid hydrolock.
Old Jun 18, 2007 | 12:00 PM
DustinZ33's Avatar
DustinZ33
I don't know what the problem is but I think you should take it to the dealer. It's an 06. Don't you have a warranty?
Old Jun 19, 2007 | 03:23 AM
FlyingSquirrel
Thanks for all the help gentlemen. As it turns out, what i put in the tank after all this trouble started was just fuel injector cleaner. I'll throw some "Heat" in the tank and if that doesn't work, then i'll get some of that CRC for the MAF sensor. I hope they sell it on base...
I'll report back and let you guys know how I get on.
Oh, and I'm trying to avoid taking it to the dealer, with the intake and all... i don't want them to try and blame the problem on me, or even worse, try and void my warranty.
Old Jun 19, 2007 | 03:45 AM
sumfknguy's Avatar
sumfknguy
its just an intake... it should take you maybe 20 minutes to swap it out?
Old Jun 19, 2007 | 04:23 AM
rcdash's Avatar
rcdash
car is in limp mode - need to get the code to figure out why. go to autozone and have them read it for you. or find a friend with cipher.
Old Jun 19, 2007 | 04:51 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
sounds like the throttle body either got unpluged or never relearned its self. I would try un-plugging the throttle body and leaving it unpluged for a while then relearn it. All you have to do is take leave your foot off the gas and turn the key to on for 10 sec and off for 3 do that 3 or 4 times and it should relearn the throttle body. That may not be it but I know they can cause those same symptoms.
Old Jun 19, 2007 | 06:36 AM
Lawy'dU's Avatar
Lawy'dU
The NISMO CAI does NOT take only 20 minutes to swap out. I don't know of any CAI that takes only 20 minutes to swap out since you have to jack the car up, remove a wheel and rip open the bottom part of the car including the fenderwell for starters.
Old Jun 24, 2007 | 10:40 PM
FlyingSquirrel
The error code was P2101....something to do with the throttle parameters..etc. I just cleared the code with the diagnostic tool and everything seems to be fine now. Not sure what the problem was in the first place... probably PFM.
I just hope it doesn't happen again.
Old Jun 27, 2007 | 06:58 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
your car should still be under warranty, take it to the dealer and let them worry about it.
Old Jun 28, 2007 | 10:19 AM
Breakin Newz's Avatar
Breakin Newz
Not sure if you guys have a camshaft Position Sensor... But if you do you might want to check that out... Usually if the sensor is ruined it will idle very high and usually will not let you pass around 4,000rpms...
trace1
Nov 27, 2011 11:18 AM
ekelly36
Oct 26, 2008 05:11 PM
