Ticking axle
Old Jul 7, 2007 | 12:58 PM
michael815's Avatar
michael815
Default Ticking axle
Ok I have searched and I do know there is a tsb on the clicking axle, but is there a problem with not doing anything about it right away.
My z is an '03 that I bought used.
I do not know how long it has been doing this.
I can't get it to the dealer for about a month because it is my dd and the dealership is way out of my way from work.
Is this a big problem or just an annoying noise?
Thanks for any help.
Old Jul 7, 2007 | 07:31 PM
michael815's Avatar
michael815
someone on ********* say's that the axle can snap.
Has anyone heard of this happening?
Old Jul 8, 2007 | 09:21 AM
Z04's Avatar
Z04
think about it. the TSB is to replace and fix the outer axle joint and wheel bearings. if you reread the post it says it could snap if you put it under heavy stress. if you have to drive for a month until it gets fixed, i woudl suggest you take it easy and not put it under too much stress.
Old Jul 8, 2007 | 09:31 AM
pln2311's Avatar
pln2311
I had something similar happen back in 04, if I remember correctly all the dealer did was grease it. Not a big deal
Old Jul 9, 2007 | 04:49 PM
michael815's Avatar
michael815
ok, so I get 2 replys and they are both gave different advice.
I'm soooo confused.
Old Jul 9, 2007 | 05:24 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the TSB is simple...you can read about it on Nissan's site in fact
http://www.nissantechinfo.com/nissan...0(Z33)%2003-07
Thought I think you have to subscribe to view the full file...anyway, not really important
the dealer will not swap your axle. Instead they will oil the bolts and retorque them to a higher spec...that's it
Old Jul 11, 2007 | 10:21 AM
michael815's Avatar
michael815
Well I had a chance to get to the dealer and they just called and fixed my ticking axle.
I showed up there this morning with the TSB in hand and they said they would look at it.
They called and said I was right and fixed it for free.
I still had drive train warranty left so I guess they used that.
I will pick it up in a couple of hours .Sure hope it is fixed.
Old Jul 11, 2007 | 10:44 AM
ZCor's Avatar
ZCor
so any clue what they did? did they just grease it up or what? im having this same "ticking axel" i think on both sides..
Old Jul 11, 2007 | 11:59 AM
michael815's Avatar
michael815
I don't know anything except they said that they lubed it.
I will get more info when I pick it up.
But get the TSB # and print it out for them.
You can find it on here.or on Nissan web site.
Old Jul 11, 2007 | 12:02 PM
Z1 Performance
Former Sponsor
read my post......
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
Daniel_dh
Sep 7, 2015 12:56 PM
jake280
Mar 19, 2004 01:17 PM
j's350z
May 8, 2003 11:18 AM
