Why isn't this Valve Body working?
Old Jul 20, 2007 | 01:19 PM
DanielW's Avatar
DanielW
i don't think thats the issue. I'm not sure exactly what it is but i don't think that's it
Old Jul 20, 2007 | 05:40 PM
Mr_pharmD's Avatar
Mr_pharmD
i just sent my 05 VB to SGP. I hope it doesnt mess it up.
Old Jul 20, 2007 | 06:29 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Originally Posted by Mr_pharmD
so wat was the problem? the +05 VB arent interchangeble with other trannys except it's orginal tranny due to the TCM? So if u sent your own VB to get it done it shouldnt be an issue, correct?
If you send your own you shouldn't have any problems
Old Jul 20, 2007 | 07:15 PM
rcdash's Avatar
rcdash
I think one of the main issues is that we cannot read the TCM over the CAN bus. As far as I know (and I have checked with several shops), no one has cracked the TCM firmware. If you could read that, I would speculate that not only would some of the mechanical modifications be unnecessary but problem cases like this wouldn't be such a mystery...
Old Jul 20, 2007 | 07:39 PM
roncfpz's Avatar
roncfpz
I believe you need the Consult to read any codes in the TCM. The 5AT is certainly a challenge to say the least. It sounds like possibly a TCM issue. Who did the install? Are you sure it is an 05 VB?
Sharif had a customer that actually had 2 faulty valve bodies. The odds of that are pretty small but nonetheless possible.
SGP has a fair amount of experience with auto trans and I have not heard of any issues with their VB upgrade. I would count on at least a couple of weeks. Call Mark or Thomas @ SGP to get you VB done ASAP.
I believe GTM is now offering a rebuilt 5AT also but not sure if they are doing VB upgrade only.
I'm really hoping the SGP trans going in next week works well.
Old Jul 20, 2007 | 08:10 PM
Cube's Avatar
Cube
I have an '03 FX35 and looking for a VB upgrade
If it's not working between 350Z/G35 and FX35, do you think the '03 to '05 difference will definitely not work?
Old Jul 20, 2007 | 08:27 PM
roncfpz's Avatar
roncfpz
Def will not work. You should use the same year. The TCM module was moved inside the VB starting in 04.5. You might be able to do 03-04, but def not 03-05.
Old Jul 21, 2007 | 02:32 PM
Cube's Avatar
Cube
Ah crap, thanks.
Old Jul 21, 2007 | 07:45 PM
DanielW's Avatar
DanielW
nah man it just didn't work on my car because its red. It should work on yours though
SharX59
Sep 30, 2015 10:54 AM
