How difficult would it be...
Old Jul 16, 2007 | 07:22 AM
Juicehead's Avatar
Juicehead
Default How difficult would it be...
to install a Nismo LSD in Base model at home? I realize changing out pumpkins would be fairly easy but what about straight LSD install.
any info appreciated...can't find much in searching for this
Old Jul 16, 2007 | 07:27 AM
Escobar's Avatar
Escobar
I have never done it but from the info I have gathered it is fairly difficult to do. I am not going to attempt it. I just did the full pumpkin swap. You can send it away to a shop and they will do it for you.
Old Jul 16, 2007 | 10:29 AM
Lawy'dU's Avatar
Lawy'dU
I've done one on my 300zx. It's not difficult at all. It's actually pretty easy. Just put your car on jack stands and put your jack underneith the housing and unbolt everything.
Old Jul 16, 2007 | 11:51 AM
DustinZ33's Avatar
DustinZ33
this is what you do to take out the pumpkin. not install an lsd. he was asking about install the lsd, not removing the pumpkin.
Old Jul 16, 2007 | 11:55 AM
SuperBlack350z's Avatar
SuperBlack350z
+1
Old Jul 16, 2007 | 12:01 PM
TENGAI's Avatar
TENGAI
I don't think it would be that bad... I've seen it done on the speed channel and aside from an impact wrench, and rubber mallet, all you would need is a set of ballz and workbench to make the swap a DIY project.
Too many people are afraid of working on their own cars. It's not rocket science. Just be patient and do you homework up front.
Old Jul 16, 2007 | 01:54 PM
Juicehead's Avatar
Juicehead
I believe the only difficult part is the actual "shimming". I have no way of doing this.
Old Jul 16, 2007 | 03:44 PM
MDeezy's Avatar
MDeezy
amen to that.
Old Jul 19, 2007 | 02:26 PM
XuperXero's Avatar
XuperXero
+1
I have helped my friend do a DIY install with his Kaaz 2-way. In the end we got it all together, only to realize that we had no way of shimming it. We just took the diff installed in the pumpkin to a local drivetrain shop and had it shimmed and then put pumpkin cover back on and install back on car.
Old Jul 19, 2007 | 07:23 PM
chichi506's Avatar
chichi506
Originally Posted by XuperXero
+1
+2
Old Jul 22, 2007 | 05:36 AM
Juicehead's Avatar
Juicehead
+1
Can this be done in a day?
jlb
Oct 15, 2017 05:10 AM
Mattg350z
Oct 2, 2015 06:51 AM
SharX59
Sep 27, 2015 09:23 AM
stecki
Jun 29, 2002 11:54 PM
