2007 - Engine Hood Very Hot to the touch
Old Jul 24, 2007 | 02:04 PM
dmw5678's Avatar
dmw5678
Default 2007 - Engine Hood Very Hot to the touch
I have a 2007 350z with less than 200 miles -- My Hood gets a real toasty after a short run granted its 82 degrees outside. Warms up my garage a few degrees. Is this normal, seems like an engine fan should stay on a while to cool this beast down?
Old Jul 24, 2007 | 02:11 PM
Tac-M's Avatar
Tac-M
Even though I don’t have a turbo, I turn off the ac a few minutes before I get to my destination and let the car idle for a little bit to cool off.
Of course, I also let it warm-up before I go anywhere.
Old Jul 24, 2007 | 03:06 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
dmw5678, the sun will obviously have a bearing on how hot the hood will get. May I suggest if you think this continues to be a concern, use a proper automotive temperature gauge and place on effected area immediately after stopping. Something I would also suggest is have a couple of 350's with the same set/year up do the same run and do exactly the same thing, oh and don't switch the engines off until you have your readings. Make hast to get your readings as temperatures drop very quickly. I've used this scenario in the past myself a few times for comparitive readings.
Old Jul 24, 2007 | 03:09 PM
VIZAGE's Avatar
VIZAGE
Yes it's normal. I was in the same boat as you when i first experienced this. Come to find out it's normal. It will stay hot for hours. My garage hits up alot also. This is why I like my Seibon hood. At a stop you see all the heat coming from the vents.
Old Jul 25, 2007 | 09:31 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Stop hallucinating problems with your cool sports car... learn to accept the sounds and smells and temperatures it makes.
Chances are, unless you have a check engine light or your temperature gauge goes into the "H" region, no problem.
Old Jul 25, 2007 | 10:11 AM
jpc350z's Avatar
jpc350z
Hot engine bay's seem to be normal for this car.. The concern I have is the effect the heat may have on non metallic items like cables, plastics etc..The one thing I try to do when feasible is open the hood after shutting down and leaving it till it cools down..
Old Jul 25, 2007 | 12:51 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Overkill...
Nissan engineers are not that stupid... they have selected plastics and rubbers that stand up to engine bay heat.
What I do is shut off the A/C (if it is running) for about 20 seconds before shutting the car down... which dries up condensation in the vents and helps the motor cool down as well.
You don't need to pop the hood unless maybe you just got through an autoX course (high load at low speed) or just did an uphill canyon run and suddenly stopped
Old Jul 25, 2007 | 12:52 PM
dmw5678's Avatar
dmw5678
I do the same in my garage open and the hood turn on a fan blowing out the door. Sometimes, at night when its cool, I just leave the car in driveway for a few minutes. Seems like the internal radiator fan would stay on for a few minutes to help cool the engine. As stated, I cannot touch the hood of the car when I fist turn it off after 10 minutes of driving in 80 -90 degree weather here in NJ. Seems very unusal, but this is a Sports Car. Actually, I can feel the heat from the engine when I wear flip flops from the drivers seat during driving. The temp guage reads normal, so I'm going to ignore this for now.
Old Jul 25, 2007 | 12:53 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
The floor under the passenger and drivers seats gets hot because your feet are right over the catalytic converters, which get pretty hot
Old Jul 25, 2007 | 03:06 PM
taurran's Avatar
taurran
Running engines get hot, so do things that are close to them. Don't worry about it and enjoy the car.
Old Jul 25, 2007 | 03:48 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you guys are being overly **** for absolutely no reason whatsoever
Old Jul 26, 2007 | 07:43 AM
jpc350z's Avatar
jpc350z
I agree but who are you referring to?? The hood openers or the don't worry and be happy guy's...Nissan engineers have taken care of your concerns
Old Jul 26, 2007 | 07:49 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Obviously the hood openers...
Old Jul 26, 2007 | 07:57 AM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
It's normal. Mine heats up my garage by a few degrees as well. The tighter engine bays do keep the heat in a little more, but it's really not that bad on a stock car... you should feel a turbo car after running around town, those get HOT.
Old Jul 26, 2007 | 11:59 AM
IIQuickSilverII's Avatar
IIQuickSilverII
true
Old May 19, 2022 | 03:01 AM
Shivam_k's Avatar
Shivam_k
Wow, who knew that engines get hot
Old May 19, 2022 | 03:43 AM
travlee's Avatar
travlee
Master
almost 15 year dead thread bump
Pleask
Dec 21, 2021 03:17 PM
Alexreyes
Sep 30, 2015 11:30 PM
