question after 3.5 FD swap
Old Jul 29, 2007 | 11:10 AM
phatz33's Avatar
phatz33
Default question after 3.5 FD swap
I swapped my 5AT 3.3 rear with a 6MT 3.5 fd. I noticed the other day that when I'm in 2nd, it redlines before it hits 60mph, is this correct because I remember that it used to be a tad over 60mph at the end of 2nd.
Old Jul 29, 2007 | 06:06 PM
05Z33's Avatar
05Z33
that's how it works. haven't you noticed the quicker acceleration. Now you go through every gear faster making your car go faster.
Old Jul 29, 2007 | 06:17 PM
The Tech-1's Avatar
The Tech-1
Bwaaahahaha not nowing what a mod does but installing it anyway. Priceless!
Old Jul 29, 2007 | 06:23 PM
Jason333's Avatar
Jason333
hi
Spelling "knowing" as "nowing" in a flame.... priceless
Old Jul 29, 2007 | 06:54 PM
sentry65's Avatar
sentry65
the burninator
going with shorter gearing means each gear doesn't go as fast as it used to, but accelleration and gear torque increases
Old Jul 29, 2007 | 07:44 PM
Zerk's Avatar
Zerk
That is correct. With the shorter gears you may also lose cruise control because the ECU doen't recognize what speed you are going. My car my have cruise one day and not have it the next day. Also your car will rev higher at any given speed comared to before with longer gears. For example I noticed my RPMs went from 2900 to 3100 at 80mph.
Old Jul 29, 2007 | 09:20 PM
z2g's Avatar
z2g
Goes good with a vortech S/C. I did that swap with my car and makes a hella difference. Bad side car consumes a lot of gas
Old Jul 29, 2007 | 11:18 PM
phatz33's Avatar
phatz33
so do I need to get my speedometer recalibrated or is everythin fine?
Old Jul 29, 2007 | 11:29 PM
z2g's Avatar
z2g
No you are good
Old Jul 30, 2007 | 07:25 PM
The Tech-1's Avatar
The Tech-1
lol good one
Old Jul 30, 2007 | 08:56 PM
z-u-later's Avatar
z-u-later
Did you even know what this mod does before you installed it?
Old Jul 30, 2007 | 09:31 PM
MustGoFastR's Avatar
MustGoFastR
Get a reflash and raise your redline. I assume you have the non-rev-up. I did it and now redline at 7100rpm and can hit 60 in 2nd.
Old Jul 31, 2007 | 01:01 AM
phatz33's Avatar
phatz33
yes I did know what the mod did and I was just wondering if the other people that had the mod had similar results, since each car is different
Old Jul 31, 2007 | 01:29 AM
HDPDZO6's Avatar
HDPDZO6
Not when it comes to the gearing.
Old Jul 31, 2007 | 02:11 AM
phatz33's Avatar
phatz33
One of my other friends also did the 3.5 FD swap and he can still reach 60mph in 2nd
Old Jul 31, 2007 | 04:04 AM
Alberto's Avatar
Alberto
Cranky FI Owner
He likely has taller rear tires, who cares about 1-2mph difference, you could be revving to 6500, he could be hitting limiter. This is silly...
Old Jul 31, 2007 | 09:59 AM
HDPDZO6's Avatar
HDPDZO6
Agree, it is silly. With the same gearing, a vehicle will top out the same in each gear as a similarly geared car.
Caught one of the vette owners in my club bs'ing this exact same thing. After installing headers & intake, he told me he got his '03 ZO6 to 185mph. Impossible with the stock gearing he has. ~171 is max.
issyz
Jul 2, 2017 03:04 PM
