Base needs LSD
Old Jul 29, 2007 | 07:57 PM
lindelium18's Avatar
lindelium18
Default Base needs LSD
I finally picked up my first Z. That said, it is the base model so it requires some upgrades! The first thing I plan is getting an LSD. My question is which one should I get (or the pros and cons of the popular ones) and besides the actual LSD, what else will I need to buy? Thanks!
Old Jul 29, 2007 | 08:08 PM
gambino's Avatar
gambino
subbin
Old Jul 29, 2007 | 08:12 PM
lindelium18
Originally Posted by gambino
subbin
? ? Is this English? Did I miss something?
Old Jul 29, 2007 | 08:15 PM
Escobar's Avatar
Escobar
You need to search and make some decisions. Do you want the stock VLSD, Do you want a viscous LSD, do you want a clutch type LSD? What is your budget, are you going to be tracking the Z. These are all questions you need to answer before you buy. In my opinion, I would just do a pumpkin swap.
There is no reason to be ashamed owning a base model so the is not necessary. Good luck
Old Jul 29, 2007 | 08:43 PM
rocks's Avatar
rocks
Get a stock one out of a wrecking yard. 300$ and 2 hours or less of work and you will have one. You dont need a high dollar one unless you want to track your car.
Old Jul 29, 2007 | 09:09 PM
Escobar's Avatar
Escobar
Jim at Turbotoys will hook you up with one. Got mine from him, he's a good guy.
Old Jul 30, 2007 | 03:26 AM
DavesZ#3's Avatar
DavesZ#3
"subbin" is internet shorthand for "I didn't know that all I had to do was look on the Thread Tools menu at the top of the thread and pick "Subscribe to this thread", so I created a useless post to subcribe to it instead.
Old Jul 30, 2007 | 05:46 AM
ofl0926's Avatar
ofl0926
do they have a website cause i am in the market for one too.
Old Jul 30, 2007 | 06:06 AM
westpak's Avatar
westpak
SFZCC
The stock LSD sucks, if you are going to spend the money and effort might was well spend, although more, and do it right ia m looking at doing the Quaife, from what I have seen and heard it is the most streetable and civilized.
Old Jul 30, 2007 | 07:26 AM
lindelium18
Thanks for all the input. As of right now, the Z is my daily driver, and probably will be for sometime. (I live 1/2 mile from work!) That said, i do have big plans for the Z. So, I believe I will probably just get an aftermarket diff. Now realize, I am a noob here so I have no idea what a pumpkin swap is or axel stubs. Also, can someone give me a cliff notes version of the difference between the viscous and the carbon LSD's? Thanks!
P.S. Not ashamed of the Base, Ijust got shammed into it. Long story but I was told I was buying the Enthusiast, thats why the . oh well, learn from mistakes!
Old Jul 30, 2007 | 07:28 AM
Motormouth's Avatar
Motormouth
don't even bother getting a VLSD...
I have a Nismo and love it... it is loud if you are a chick. a friend has a Quaife on his G35c and it is completely transparent and hooks wonderfully. if you want a more refined product, look at the quaife.
if you want to drift or have a more agressive action, go for a clutch type (Cusco, Nismo, Kaaz, etc)
Old Jul 30, 2007 | 07:30 AM
Motormouth's Avatar
Motormouth
dude, the Base is THE BEST model you can get, be happy about it. if you are planning on lightly or seriously modifying it, it is the best, lightest starting point. No VDC, TCS, thank GOD the newer base models even get the HIDs! (the only reason to get a higher model)
phenix's Avatar
phenix
Street Car/Weekend Warrior - Quaife, Weekend Warrior/Track car - Kaaz
Old Jul 30, 2007 | 07:33 AM
Motormouth's Avatar
Motormouth
does anyone really have the Kaaz? I haven't seen many posts about it.. the Carbon ATS is more popular I thought.
Old Jul 30, 2007 | 07:42 AM
Escobar's Avatar
Escobar
http://www.turbo-toys.com/homepage.asp
Old Jul 30, 2007 | 09:31 AM
ofl0926's Avatar
ofl0926
thanks bro
Old Jul 30, 2007 | 09:43 AM
lindelium18
Thanks again! I would say right now, my biggest concern is going to be grip in the rain since this is going to be my daily driver. But in the future I may need something that can handle a little track time. What about the cusco? Also, I went to the dealer today just out of curiousity and they said the left and right stub axels would run about $1400 Does that sound about right? Anyone who has a base and did this upgrade, do you have part numbers for the stubs? Thanks again
Old Jul 30, 2007 | 09:44 AM
gsazabi's Avatar
gsazabi
Maybe I can sell you my stock VLSD? I'm thinking about upgrading to Cusco lol..
Old Jul 30, 2007 | 10:30 AM
Equinox's Avatar
Equinox
I don't have the part numbers handy, but I believe the axle stubs should run you about $300 for both. Also, some of the board vendors sell LSD "kits" that include aftermarket LSD + necessary hardware for installing an aftermarket LSD into a base model car.
Old Jul 30, 2007 | 10:31 AM
Escobar's Avatar
Escobar
Lindelium, I just did basically the same thing you are trying to do about a month ago. I have the base and wanted to get more traction on wet surfaces and around sharp turns. The best thing to do is do the whole pumpkin swap out of the other model Z's. Jim at turbo toys will hook you up with one or you can try a local junkyard. Since you have an open diff, you would need to buy the axle stubs in order to put in just the internal VLSD component in your base open diff. Jim also has those, and $1400 is a little steep, try $150. More then likely you were pricing the axles that go from the pumpkin to the wheels. If you decide to go with a clutch type LSD, such as the nismo, you can just drop it into your open differential with nothing else required, however, this is not easy to do as you have to open up the pumpkin. This may require you to have a shop do it, or you can mail it to a sponsor on this board and they will do it costing a couple hundred dollars. In my opinion, just a VLSD pumpkin swap is very easy and cheap and you can do it yourself, just bolting things up. Hope this helps, let me know if you have any questions.
