base + Quaife = driveway install?
Old Aug 14, 2007 | 11:16 AM
Midnyte's Avatar
Midnyte
Default base + Quaife = driveway install?
Just curious if anyone with a base model has installed there own Quaife LSD. If so, is there a guide somewhere that I can look over? I'm thinking about this as my next mod...but I want to make sure I get the right tools, and have the right amount of time allocated for the install. So far, I've done all my own work, and I don't want to stop now
Thanks in advance.
Old Aug 14, 2007 | 06:40 PM
Laughitup85's Avatar
Laughitup85
Ok I completely agree of the installing everything on your own, because I have done the same!! But with the rear end... I honestly suggest taking off your pumpkin, and taking it with the Quaife LSD to a differential shop and having them do the swap for roughly $150 and getting the pumpkin back with the new LSD installed and putting it back under your car... You don't want to loss your rear end!!!
Old Aug 14, 2007 | 07:21 PM
meatbag's Avatar
meatbag
Your going to have to get the correct tools to set the mesh and you'll need to order a set of shims from Nissan so you can play with the meshing. You'll also need a press to press on new bearings to the quaife lsd.
Old Aug 15, 2007 | 11:26 AM
warmmilk's Avatar
warmmilk
i'd get installed profesionally just cause installation error is the only way the quaife warranty can be voided. taking off the pumkin and taking it somewhere is as diy as i'd get with a diff
Old Aug 16, 2007 | 06:09 PM
MyCarIsMyFriend's Avatar
MyCarIsMyFriend
I may need to take my Z into the dealer soon to check out a clicking from the rear-end and probably get a warranty-fix... would they install an LSD for me while they are in there?... or do you think they will only replace the stock diff, since it is a warranty fix?
Old Aug 17, 2007 | 06:34 AM
Wheelman's Avatar
Wheelman
It's not like you have to set gear lash or anything. A press can be improvised if you have a big vise and are careful. I believe a good DIY can perform this without problems if you work carefully and take your time.
350z82
Oct 1, 2015 06:25 PM
